Booming won't stop
offroadbum
Member - Posts: 14
Posted: November 22, 2004 at 4:23 PM / IP Logged
I just installed an amp and a sub box.
 The subs just pluse BOOM BOOM BOOM.It doesn`t matter if the head unit is up or down.
I`ve rewired twice,changed amps3 times,move the ground alround the truck,but it doesnt change.
Anybody ever heard of this before? I`ve do this same install a 100 times and never had anything close to this happen.
Pioneer p440
comp vr 12`s
orion 8002
jeffchilcott
Platinum - Posts: 2,483
Posted: November 22, 2004 at 4:30 PM / IP Logged
check your speaker wiring and power and ground lines..make sure rca's are connected correctly to the deck and to the amp, that they are both in the proper in and out spots
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
offroadbum
Member - Posts: 14
Posted: November 22, 2004 at 4:33 PM / IP Logged
 I`ve gone through the wiring twice already.
Something is giving it a signal,but what??
Ravendarat
Platinum - Posts: 2,806
Posted: November 22, 2004 at 4:34 PM / IP Logged
Loose or defective RCA is my best guess
offroadbum
Member - Posts: 14
Posted: November 22, 2004 at 4:37 PM / IP Logged
 I`ve changed the rca`s 3 time and no help
Ravendarat
Posted: November 22, 2004 at 4:40 PM / IP Logged
Does it still do it if you unplug the RCA's from the amp
offroadbum
Member - Posts: 14
Posted: November 22, 2004 at 4:44 PM / IP Logged
 nopeno output at all
Ravendarat
Posted: November 22, 2004 at 4:48 PM / IP Logged
What the hell does nopeno mean, If that means no than it means that the problem lies in either the RCA inputs on the amp, the RCA outputs on the deck or the cables. If the deck has multiple out puts try hooking up to another set, Is this using a factory deck or after market?
offroadbum
Member - Posts: 14
Posted: November 22, 2004 at 4:52 PM / IP Logged
 Sorry for the typo!! nope no output
it is a pioneer p440
and yes i have changed at the deck
Ravendarat
Posted: November 22, 2004 at 4:54 PM / IP Logged
I think you need to take your amp and get it bench tested at a local shop
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
