hood pin, factory security
devile
Member - Posts: 45
Posted: November 27, 2004 at 5:37 PM / IP Logged
Ok, this might be a funny question, but i baught a haynes repair manual and there is nothing about the security system. I want to find the wire for the factory hood pin, becuase i'm installing my remote start system and i don't want to install another hood pin. Haynes should put it in there, considering, what if the security moudle went. Ok anyways, it says that when i wire up the factory security system to my RM/KE (remote start/keyless entry system) when i hit the lock button on my remote it will activate the security system, but i don't understand beucase the would be the same as me hittin the lock button if i was inside, would it not? And, what color and where is the facotry hood poin wire so i can solder my required wire to it? THanks Oh yes, 1991 Jeep Cherokee Limted 4.0L HO
auex
Platinum - Posts: 5,041
Posted: November 27, 2004 at 5:45 PM / IP Logged
Go directly to the hood pin, if there is one, it should be a pin switch with a rubber boot that will press down when the hood is closed. You can also try looking in the passenger's kickpanel for a BROWN / tan wire.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
devile
Member - Posts: 45
Posted: November 27, 2004 at 8:41 PM / IP Logged
yah i do have a factory hood pin, it's for my factory security but you didn't answer my other questions in the forum, please help. And would the wire be BROWN / tan?
Hymer
Silver - Posts: 695
Posted: November 27, 2004 at 11:31 PM / IP Logged
when you hit the lock button on th rske it sends whatever signal is needed to arm your factory alarm when you remote start this it disarms your oem alarm and allows for the starting of your jeep... I think that answers your question...
BTW test your factory hood pin to make sure it is a ground closure...
good luck
-Hymer
devile
Member - Posts: 45
Posted: November 28, 2004 at 4:31 PM / IP Logged
yah but hooking of the activation, please re-read the beginning. Thanks
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
