Changing from Positive Input to Negative Output
dereck
Member - Posts: 28
Posted: October 13, 2002 at 1:37 PM / IP Logged
Jeff what wires do you install on the relay to change the positive input on the remote starter to negative out put. Were does the glow plug wire hook to from the remote starter, and were does the wait to start wire hook to from the truck? I can see the 87 and 86 is the ground, and the 85 is 12 volt constant power. What is the 30 pin connected to?
Platinum - Posts: 12,488
Posted: October 13, 2002 at 3:12 PM / IP Logged
POSITIVE INPUT ----> NEGATIVE OUTPUT
  • 87 & 86 -  CHASSIS ground
  • 30 - Goes to the GLOW PLUG WIRE. The Dodge has a negative output on this wire.
  • 85 - This pin will be connected to the Glow plug wire of the RS unit.
  • 87a - NOT USED
Quick question..... is the GLOW PLUG wire of the RS unit that you have a (-) or a (+) input wire to sense that the glow plug is on and off ? Just want to make sure of this before you venture out into thte truck and do something wrong. = )
You probably need a system that reverses the (-) output of the Dodge to a (+) input for the RS unit right ?? If so this is the wiring diagram that you need:
  • NEGATIVE INPUT ----> POSITIVE OUTPUT
    • 87 & 86 - 12 volts +
    • 30 - This pin will be connected to the Glow plug wire of the RS unit.
    • 85 -  Goes to the GLOW PLUG WIRE. The Dodge has a negative output on this wire.
    • 87a - NOT USED
  • Jeff
    dereck
    Member - Posts: 28
    Posted: October 13, 2002 at 3:31 PM / IP Logged
    Yes the glow plug wire off the RS is +. So we have to use the second diagram right.
    Posted: October 13, 2002 at 5:51 PM / IP Logged
    Yes that is correct Changing from Positive Input to Negative Output -- posted image.
