radio on till door open ford f150
sport2001l
Member - Posts: 9
Posted: December 04, 2004 at 9:59 AM / IP Logged
i am trying to hook up the relays. used the diagram below for (-) trigger doors.  im doing this in a 2001 ford f150 without factory keyless. the door trigger i think is my problem. i tried to use the black\yellow wire in the driver kick panel.  as soon as i hook it up to 12 volt power all i get is fast ckicking noises.  what am i doing wrong????
radio on till door open ford f150 -- posted image.
Aaaudiowaves
Member - Posts: 11
Posted: December 12, 2004 at 1:06 AM / IP Logged
Maybe a bad ground or poor connection.  Any additional resistance may cause low amperage to the relays.
AA Audio Waves
Wildomar CA
MECP/ASE
Hoptup32
Copper - Posts: 87
Posted: December 28, 2004 at 7:33 AM / IP Logged
Try this wiring schematic:
https://www.the12volt.com/relays/page5.asp#drto
It's wired different from your schematic
KarTuneMan
Platinum - Posts: 7,056
Posted: December 28, 2004 at 8:24 AM / IP Logged
The astrochart shows this problem, and gives this for a fix......  Isolate the starter wire with a relay!
pin 85 gets your remote start wire
pin 86 goes to ground
pin 87 gets fused 12 volts (20amps)
pin 30 goes to your trucks starter wire     Try it ?
KarTuneMan
Posted: December 28, 2004 at 8:27 AM / IP Logged
Sorry ....I didnt read the post very well   radio on till door open ford f150 -- posted image.
