2000 Tundra Neutral Safety Switch
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: December 04, 2004 at 4:22 PM / IP Logged
Hey guys.  I'm doing an install right now and need to know which wire the Neutral Safety Switch is.  I figure it is probably in the steering column, but wasn't sure which wire.  From searching 3 different databases, only one actually mentioned it.  The Omega program I have said "not grounding type (-) OEM switch opens starter kill".  This confuses me as I'm worried that I can't just test for it by looking for a wire that grounds in the park/neutral position.  Anyone have any ideas?
Steven Kephart
Adire Audio
daniel2002p
Silver - Posts: 524
Posted: December 04, 2004 at 11:13 PM / IP Logged
this truck is alredy protected from being able to start with the grear whifter in anything but P and N, so you can just ground that wire.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Steven Kephart
Posted: December 05, 2004 at 1:02 AM / IP Logged
Awesome!  And thanks.
When I noticed it was completely mechanical I figured I was either screwed or safe.  2000 Tundra Neutral Safety Switch -- posted image.
daniel2002p
Silver - Posts: 524
Posted: December 05, 2004 at 11:25 AM / IP Logged
no problem
    1.8L VVT-i I-4
