96 saturn sc1 remote start wiring
Dream Theater
Member - Posts: 20
Posted: December 04, 2004 at 5:30 PM / IP Logged
Are the wiring diagrams for the 96 saturn sc1 and the 02 saturn sc the same? Installing a remote starter on a 96. I seen the diagram for the 02 and wanted to verify. Thank you.
mxxmikexx
Silver - Posts: 796
Posted: December 04, 2004 at 6:31 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - SATURN / SEDAN, COUPE / 1996 / Remote Start
[PRINT THIS PAGE]
12volts red    +   ignition harness or
Notes: Fuse boxes located in console and under hood. Wire colors and pin #s are as follows: RED / white constant - console pin F6. Pink ignition - console pin D8. Orange accessory 2 - console pin A6. Brown park lights - console pin F5. Purple (or yellow) starter - underhood pins F6, A2.
Starter yellow    +   ignition harness or
Notes: Can also be found purple at the clutch switch.
Second Starter
Ignition pink    +   ignition harness or
Second Ignition
Third Ignition
Accessory orange    +   ignition harness or
Second Accessory
Keysense
Power Lock lt. blue    +   either kick harness to rear
Notes: Also at factory keyless module located behind rear passenger seat behind panel.
Power Unlock white    +   either kick harness to rear
Lock Motor
Unlock Motor
Parking Lights+ brown      rear of fuse box or
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white    -   base of B pillar
Notes: Also found in taped up harness under ashtray - one of three white wires - test to identify. White at keyless module beats delay.
Dome Supervision
Trunk/Hatch Pin RED / black    -   at light in trunk
Notes: On wagons find dark green at the rear light.
Hood Pin
Trunk/Hatch Release blue    +   at lever or
Notes: Gray at factory keyless module (+).
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white   AC   ign. module
Notes: Top left rear of motor.
Wait to start
Brake Wire lt. blue    +   brake pedal switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Friday, September 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
