Trouble from ground distribution block
bigboi11
Copper - Posts: 83
Posted: December 13, 2004 at 6:24 AM / IP Logged
I have alot of engine noise coming from my speakers.  I accidentaly orderd a fused distribution block for my ground  and I have been using that could that be the cause of my trouble.
spootydlux4
Copper - Posts: 149
Posted: December 13, 2004 at 6:34 AM / IP Logged
possibly, did you run your power wires close to your rca's.? how long is your ground?
blah blah blah blah
bigboi11
Copper - Posts: 83
Posted: December 13, 2004 at 6:46 AM / IP Logged
my ground is only about 12-15 inches long
jeffchilcott
Platinum - Posts: 2,483
Posted: December 13, 2004 at 7:07 AM / IP Logged
do you have alot of engine noise from subs? from internal speakers? both?    are thier amps on both internals and subs?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
bigboi11
Copper - Posts: 83
Posted: December 13, 2004 at 7:55 AM / IP Logged
I just have alot of engine noise from the internal speakers the subs sound great.  There is a sound from the subs when i trun my head lights on and off but just for that split secound and thats it.  The internals are noisy constantly
spootydlux4
Copper - Posts: 149
Posted: December 13, 2004 at 5:55 PM / IP Logged
what about your power wire? are you running 2 different wires or one with a distro block to the 2 amps? and how close are your power wires from your rcas?
blah blah blah blah
bigboi11
Copper - Posts: 83
Posted: December 13, 2004 at 8:08 PM / IP Logged
I am running four gauge to the dist box and 8 out and I ran the power on the opposite side of the car
ravenndude
Silver - Posts: 250
Posted: December 13, 2004 at 11:49 PM / IP Logged
I jsut read this from http://www.bcae1.com/ thought it might apply:
"When making any connections in your audio system, remove all power from the system. One reason (there are others) is that the shield of the RCA connectors is connected to chassis ground in at least one audio component (almost always grounded in the head unit). If, at any time, the shield is allowed to come in contact with any power source, the component with the grounded shield connection will be instantly (INSTANTLY) INSTANTLY damaged (Oh, did I say instantly damaged?). This is one of the most common causes of loud engine noise and it is VERY common."
dragonrage
Copper - Posts: 193
Posted: December 16, 2004 at 1:40 PM / IP Logged
Try a capacitor. It need not be something huge meant to help with power problems. Even a few mF should help somewhat. Just make sure the voltage rating is at least 16V, preferrably 20+.
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
forbidden
Platinum - Posts: 5,354
Posted: December 16, 2004 at 3:42 PM / IP Logged
The fused distro block has nothing to do with this. List the equipment and the vehicle year,make, model. What you have is more than likely a difference in ground potentials. Any chance that you have a Pioneer head unit?
Page of 3
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
