New setup need help?
eeh1025
Copper - Posts: 113
Posted: December 14, 2004 at 6:33 PM / IP Logged
Hey there im getting these subs
2 ROCKFORD FOSGATE STAGE 1 P112S4 12" subs
Which amp would be better for SQ
1 HIFONICS ZEUS ZX4000 2-CH AMPLIFIER
1 Rockford fosgate Punch P300 2-CH
Ravendarat
Platinum - Posts: 2,806
Posted: December 14, 2004 at 6:36 PM / IP Logged
I know nothing about that HIFONICS amp but if you decide to go rockford then get the 3001 not the 3002. You want a mono amp capable of running 2 ohms mono, that Rockford amp wont do that and that HIFONICS might not either so check it out first.
eeh1025
Copper - Posts: 113
Posted: December 14, 2004 at 6:41 PM / IP Logged
Yes your right i would just go with the 4omh p1 then.
Ravendarat
Posted: December 14, 2004 at 6:46 PM / IP Logged
ok both the p1 and the p2 are both single voice coil 4 ohm drivers so if you want to run two of them then you must get an amp that is 2 ohm stable, at least if you want to run them effectivly.
wheelerdr
Copper - Posts: 337
Posted: December 16, 2004 at 8:59 AM / IP Logged
I would go to locustaudio.com and get a kenwood 811d this amp will do 4,2,or1ohm 230.00 great amp and will give you upgrade option later if you want better subs but for a little more i would get the 2 p3 dual 4 ohm  in a ported box and wire them for 1ohm and push 1000 watts from this amp and you will give yourself a heart attach from the bass
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
