Glow plug multiple warmup before RS
forbidden
Platinum - Posts: 5,354
Posted: December 20, 2004 at 6:54 PM / IP Logged
04 Dodge 3500 - I have a customer interested in remote start and he has a fairly specific request. He works in Ft. McMurray where it is hella cold, way hella cold for you US guys. He wants to warm his glow plug circuit multiple times before the remote start process. Have any of you guys come across this before?
auex
Platinum - Posts: 5,041
Posted: December 20, 2004 at 7:17 PM / IP Logged
Nope, can't say that I have.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
daniel2002p
Silver - Posts: 524
Posted: December 20, 2004 at 7:25 PM / IP Logged
i guess that you could use one of the aux outputs of the alarm and wire up a relay to turn the ign on and warm the plug, other than that no.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
msaskin
Posted: December 20, 2004 at 9:12 PM / IP Logged
Something to consider is that on the majority of trucks the "wait to start" light is only only for about 10 seconds or so, but the plugs really stay on much longer.
I only have direct experience with ford diesels, but I know on my excursion that even after the wait to start light goes off the plugs are hot for about 90 seconds or so.
If you come up with some solution using this info, let me know since I'd like to do the same :)
~matt
jcap
Member - Posts: 41
Posted: December 20, 2004 at 11:24 PM / IP Logged
on the  2004 dodge there are no wire for wait to start. you need to use a remote start that has a time delay or hook
up a time delay  module.
jcap
