2003 Cavalier Passlock II
baldy51497
Posted: December 24, 2004 at 2:13 PM / IP Logged
I have the DEI Passlock bypass module and the car is starting and then stalling.  I am using a Ultra Start 1250.  I have the pink wire to ignition, the yellow wire to the cylinder side of the yellow in the ignition, the BLACK / YELLOW wire to the car side of the yellow cylinder wire.  The all black wire tapped into the black wire at ignition.  I am connecting the blue wire to the orange wire on the remote start module.
mo12v
Posted: December 24, 2004 at 6:33 PM / IP Logged
R U sure the ORANGE wire is Output while Running?? Try grounding the BLUE wire from DEI BYpass and Remote Start it.
  I thought the ORANGE wire from 1250 was Negative output for Starter Kill
MO
baldy51497
Posted: December 25, 2004 at 12:34 PM / IP Logged
mo 12v
I am sorry to bother you, I found my problem.  I was getting desperate because it was a christmas present.  I was connecting the plug to the DEI bypass module in tight quarters and didn't get the plug in all the way.  So I got it now.  Thanks for your time, these forums are great things.  I really answered a lot of questions by reading previous posts.  But I got it all set now, it runs great.
