crossover with stock deck
H2prix
Member - Posts: 27
Posted: December 27, 2004 at 7:10 PM / IP Logged
I was wondering if it was possible to have an awesome sound, using a LOC and a high end crossover..? Don't get me wrong my setup sounds good for me right now, but its missing some of the mids from my heavy bass hits, it just doesnt sound right..Could you run a line level out converter, straight to a crossover, and have the ability to exact the crossover points and all. I have a 00 grandprix gtp with a bose system, that has a external ampilifer. Would this ampilifer mess with that crossover and ruin things, or would it work??
Thanks.Brett
geepherder
Platinum - Posts: 3,668
Posted: December 27, 2004 at 8:33 PM / IP Logged
With the Bose setup, the factory crossovers are inside the amps themselves.  You're better off just replacing the whole system.
H2prix
Member - Posts: 27
Posted: December 27, 2004 at 9:00 PM / IP Logged
No other way out huh?
H2prix
Member - Posts: 27
Posted: December 27, 2004 at 11:44 PM / IP Logged
The bose setup i have does sound "decent", but does not compare to any aftermarket component setups im sure..I would like to know some way possible to get around this situation without replacing the whole entire bose system.
Help out please
stevdart
Platinum - Posts: 5,816
Posted: December 28, 2004 at 12:47 AM / IP Logged
Check into these PAC products to allow interfacing a separate amplifier to run additional speakers.  You could work on adding the missing sounds instead of trying to modify the current bose system.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
