02 Civic Alarm
kendrick20
Member - Posts: 23
Posted: October 20, 2002 at 12:34 AM / IP Logged
Waz s'up y'all!!!!!
I just bought a brand new alarm (CRIME Guard) from Ebay.  I've already read the installation manual book, but it kinda hard to understand. Can you guys help me to get start it. I can bring my car to the shop and they will install it for $50.   But I don't want them to mess up my car so I try to do it by myself.
By the way, my car is 2002 civic 4drs LX
thanks alot............
Sound Pressure
Silver - Posts: 711
Posted: October 20, 2002 at 12:45 AM / IP Logged
https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=7&TopicID=4624&SearchPagePosition=1&search=2002+honda+civic&searchMode=allwords&searchIn=Thread&forum=0&searchSort=dateDESC&ReturnPage=Search
The wiring diagram was provided through a previous post from Jeff. Hope this will help you out. Don't forget to use a multi-meter to test all wires before you connect them.
Sound Pressure
Moderator - Posts: 12,488
Posted: October 20, 2002 at 8:48 AM / IP Logged
If that's all they are charging you for the WHOLE installation .... go for it !! The vehicle requires you to bypass the Immobilzer chip in the key and these modules alone are worth about $ 30.00 US. Did they say that everything was included for the $ 50 ? I would let a professional do this install if I were you.
kendrick20
Member - Posts: 23
Posted: October 20, 2002 at 8:22 PM / IP Logged
Oh NO Jeff, just for the installation (without parts), But by the way I just got the alarm installed today. BY MYSELF.  THANK YOU SO MUCH FOR YOUR HELP GUYS, I APPRECIATED. And I got a little question, I can't find where is the door trigger at (drivers trigger is green, front passenger door trigger is light GREEN/ red. and the rear door trigger is GREEN / WHITE).
And where is the "factory alarm plug" (green plug above the drivers kick panel<I'm sorry but I don't know where the hell it is.>)
And 1 last thing,  It's seem that the sensor doesn't work, I install it properly (i mean 100% right).
Thanks for your help guys
Posted: October 20, 2002 at 8:40 PM / IP Logged
  • The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE. Diode isolate each trigger point from each other.
  • It may be high above the fuse box or taped up high along side the radio side of the kick panel
  • The impact sensor may have a delay on it before it's actually activated. Make sure you give it about 2 - 3 minutes before you try to test the sensitivity.
kendrick20
Member - Posts: 23
Posted: October 20, 2002 at 10:43 PM / IP Logged
Thanks Jeff!!!!!
Where can I buy the relays at?
And what is "diode" mean?
Posted: October 21, 2002 at 7:43 AM / IP Logged
You can buy relays and diodes ( https://www.the12volt.com/diodes/diodes.asp ) at any electronics store like Radio Shack, Stereo Shop or an Electronics Repair shop.
Nonono333
Member - Posts: 22
Posted: October 21, 2002 at 10:01 PM / IP Logged
what do you need the relay for? apparently there is no use for relays if everything works A-O-K. but you will need the diodes..if you go to radio shack, ask for 1amp diodes...if you need help on understanding diodes, or how to hook it up...go here.......https://www.the12volt.com/diodes/diodes.asp
good luck
steve p.
kendrick20
Member - Posts: 23
Posted: October 26, 2002 at 12:03 AM / IP Logged
Hey, is me again.
I don't know which wire is the "door pin switch(+), hood pin switch, door pin switch (-), Dome light output, door lock outputs, and trunk release wire"
Thanks alot for your help guys........
Posted: October 26, 2002 at 9:02 AM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ red           |+  |ignition harness            |
|       POWER LOCK|WHITE/ blue          |-  |gray plug above drivers kick|
|     POWER UNLOCK|WHITE/ green         |-  |gray plug above drivers kick|
|       LOCK MOTOR|yellow/black        |   |back of the fusebox *3      |
|     UNLOCK MOTOR|YELLOW /GREEN        |   |back of the fusebox *3      |
|    DISARM DEFEAT|yellow              |   |back of the fusebox *3      |
| PARKING LIGHTS +|RED / black           |   |back of the fusebox         |
| PARKING LIGHTS -|blue                |   |factory alarm plug *1       |
|       HEADLIGHTS|blue/red            |-  |headlight switch            |
|     DOOR TRIGGER|*2                  |-  |factory alarm plug *1       |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|red                 |-  |factory alarm plug *1       |
|       TACHOMETER|blue                |   |test connector *4           |
|      SPEED SENSE|WHITE/ green         |   |PCM *5                      |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|orange              |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|-  |steering column             |
|  LF WINDOW UP/DN|RED / blk - RED / yel   |A  |drivers window switch       |
|  RF WINDOW UP/DN|blu/red - blu/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|brn/wht - brown     |A  |drivers kick panel          |
|  RR WINDOW UP/DN|blu/org - brn/yel   |A  |drivers kick panel          |
|        RADIO 12V|WHITE/ red           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|grn/blk - lt green  |   |radio                       |
|       RF SPEAKER|grn/yel - gry/red   |   |radio                       |
|       LR SPEAKER|blu/wht - blu/blk   |   |radio                       |
|       RR SPEAKER|pink - blu/yel      |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.   *1 The factory alarm plug is a green plug above the drivers kick panel.  *2 The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE.  *3 In the top left plug.  *4 It is a 2 pin plug to the passenger side of the battery.  *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
