94 Camry Alarm/Remote Start
karma
Member - Posts: 12
Posted: December 30, 2004 at 2:47 PM / IP Logged
Where can i find the diagram to setup remote start on a 1994 Toyota Camry Coupe using a Viper 790VX alarm and remote start module?
snguyen
Silver - Posts: 281
Posted: December 30, 2004 at 2:51 PM / IP Logged
Toyota
Camry
1994-1996
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition #1:
BLACK/ ORANGE
Ignition #2:
BLACK / YELLOW
Ignition #3:
N/A
Accessory:
PINK/BLUE
Brake Light:
GREEN / WHITE
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK
AT DIAGNOSTIC CONNECTOR *
Parking Lights:
GREEN (+)
AT FUSE/JUNCTION BLOCK ('TAIL'FUSE)
Headlights:
RED / YELLOW
(-) AT HEADLIGHT SWITCH
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Diagnostic Connector Located On Passenger Rear Of Engine Compartment. 6 Cylinder Engine- BLACK Tach Wire Located On Driver Strut Tower.
Toyota
Camry
1994-1996
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE AND WHITE/ RED
OEM Alarm Disarm:
N/A
Dome Lights/Superv:
RED / WHITE (-)
FUSE/RELAY BLOCK - DRIVER KICK PANEL
OEM Horn:
GREEN/ BLACK
(-) STEERING COLUMN HARNESS
Power Lock:
LIGHT GREEN
BLUE # PIN CONN. IN DRIVER'S KICK **
Power Unlock:
DARK GREEN
Trunk Release:
BLUE/BLACK (+) # PIN
CONN.DRV KICK (WAGON ONLY)
Alarm Input Wire:
RED / WHITE (-)
Notes:
** Child Safety Locks- BLUE/RED At Pin #9 In Same Connector As Door Lock Wires Above. See Note #209 - Child Safety Door Lock Diagram.
karma
Member - Posts: 12
Posted: January 12, 2005 at 2:18 PM / IP Logged
Ok i have a question.  On the drivers side kick panel is the RED / white wire that cnotrols the dome light.  Which plug is it on.  I saw 3 different wires on there and when i unplugged each plug they didn't turn off the dome light.
Also how do i hook it up so that my 790vx turns on my dome light when i unlock the doors? how do i hook a relay to it? do i splice it?
Jschult3
Copper - Posts: 106
Posted: January 12, 2005 at 4:11 PM / IP Logged
Check out the section on this site that talks about relay's. The diagram below is for Neg door triggers. If you have positive triggers pin 87 gets tied to pin 85 instead of ground.
94 Camry Alarm/Remote Start -- posted image.
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
karma
Member - Posts: 12
Posted: January 12, 2005 at 5:56 PM / IP Logged
I'm trying to hook up Remote Start in my 94 Camry and i have a question.  I'm using the 790vx Viper alarm and the proper remote start modules for the install.  I'm confused about placement of a couple wires when it comes to the Remote Start.
1)  On ignition 1, if i place the wire that detescts voltage for Zone 5 (ignition) protection on this circuit, do i have to place the ignition power wire from the Remote start relay further away from the lock solenoid(more down stream)?
2) If i do have to put it further down stream, do i have to put a diode in line on the Ignition wire to keep power from going backwards up the sensor wire and cycling back in to the alarm or does it matter?
3) Does the ignition sensor wire and remote start ignition output wire have to be further down than the ignition wire i have hooked up to the Failsafe starter kill relay? Like so....
   Key switch]-----X---------------------------------------X----------------------------------------X-->Ignition1
                              StarterKill                                      Sensor                                            Rte Start
Thanx
karma
Member - Posts: 12
Posted: January 12, 2005 at 6:02 PM / IP Logged
Also, i forgot, Do i have to place a diode inline with my starter kill relay ouput so that the current doesn't go backwards when i activate my Remote start and electricity runs from the starter output relay and in to the same wire the starter kill is hooked up to?
karma
Member - Posts: 12
Posted: January 12, 2005 at 7:03 PM / IP Logged
If i do it like that won't it show as the doors being open and set off Zone 3 in my alarm.  I just want to set it up to turn on my dome light not just trigger the door to think it's open and turn on the dome.
Jschult3
Copper - Posts: 106
Posted: January 13, 2005 at 11:40 AM / IP Logged
1) NO- should not need to as long it's connected.
2)NOPE
3)WHat do you mean about being further downstream, are you referring to the key sense wire?
No diodes needed unless your paranoid. Do you have the install manual for the 790xv? It should be very specific about where you need to place any diodes. The only time you need a diode in starter kill with this alarm is if your using a window module which is also connected to the orange wire as is the starter kill.
CutDog504
Silver - Posts: 643
Posted: January 13, 2005 at 11:27 PM / IP Logged
About the "RED / white" wire you mentioned for the door trigger... Most toyotas have several RED / whit wires in the kick panel. You have to probe them and find out which is the right one. Also, one of those RED / white wires is the trunk trigger. Connect it to the blue wire on your alarm and it will trigger your alarm if anyone opens your trunk.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
