99 dodge durango doorlock problem
Scott105
Member - Posts: 29
Posted: October 20, 2002 at 9:16 PM / IP Logged
I have a 99 durango slt. I just hooked up a prestige 995 remote start to it . Evreything else is working except the doorlocks this vehicle has a factory keyless entry unit. I tried hooking up a DLS-2 dr lock interface because it is a reversal at ground rest circuit but it still does not make the alarm pop the locks should I use a DEI 452T Door lock pulse/double pulse generator unit to fix this problem.  Also this vehicle has drivers door lock priority.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 21, 2002 at 12:12 AM / IP Logged
Looks just like a plain ol' positive-trigger system to me.
|              12V|red or pink/black   |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|ORANGE / purple       |+  |blue plug in                |
|     POWER UNLOCK|pink/purple         |+  |drivers kick panel          |
|       LOCK MOTOR|ORANGE / black        |   |drivers kick panel          |
|     UNLOCK MOTOR|blue                |   |drivers kick panel          |
|    DISARM DEFEAT|pink/black          |   |drivers kick panel          |
| PARKING LIGHTS +|BLACK / YELLOW        |   |*1                          |
|       HEADLIGHTS|lt. green           |-  |steering column             |
|     DOOR TRIGGER|blk/blu & tan/red *2|-  |*1                          |
|  TRUNK/HATCH PIN|tan/black           |-  |*1                          |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|lt. GREEN/ orange    |-  |*1                          |
|       TACHOMETER|BLACK/ gray          |   |ignition coil               |
|       BRAKE WIRE|WHITE/ tan           |+  |at brake pedal switch       |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|*3                  |+  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |C  |at drivers door switch      |
|  RF WINDOW UP/DN|brn/wht - brn/wht   |C  |at drivers door switch      |
|  LR WINDOW UP/DN|blu/wht - RED / blk   |C  |at drivers door switch      |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |C  |at drivers door switch      |
Notes:
*1 Located at a black plug in the drivers kick panel.   *2 The BLACK/ blue catches the drivers door and the tan/red catches all other doors.  Use both wires and diode isolate each.  *3 Use GREEN/ red for intermittent, purple for low, and RED / gray high.
djfearny2
Silver - Posts: 810
Posted: October 22, 2002 at 7:01 PM / IP Logged
this is easy your alarm should be putting out a pos and a negative  all you have to do is find the ORANGE / purple wire (power lock ) and the pink purple (power unlock. not the two wires for the motor side stated above. you want the power lock/unlock mod cause that goes into the relays and controls all the locks . now after you find them experiment take one wire from alarm and connect it to one and the other to the other, if the door locks work opposite. lock on remote unlocks  etc, than switch the two wires , what happens is all alarms send out a negative when on one wire and a poss on the other so a possitive system is easy . if you need more help email me and i will tell you what you need to know
Jon
Installer/Help Technician
---coral springs florida---
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
