2003 chevy venture Remote starter
Hymer
Silver - Posts: 695
Posted: January 12, 2005 at 9:49 PM / IP Logged
To avoid the domelight delay use tan for the driver door, blue for the passenger door and the liftgate, and orange for the sliding doors. All wires are negative trigger, located at the BCM and all need to be diode isolated from each other.
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
firefighter321
Member - Posts: 9
Posted: January 12, 2005 at 10:03 PM / IP Logged
I haveing problems bypassing PK3 on chevy venture it was working at one time now it is not .  anyone have any idea what could of went wrong. I am installing  the mannix sm700.
Sexified
Copper - Posts: 87
Posted: January 12, 2005 at 10:40 PM / IP Logged
yes, use the dei product #555g data system specific for that venture based on it's year.
don't bother with the 556u it's a great product but the transponder interfeas with the factory system, unless you beak open the keysense wire, and it's really not worth the effort.
change it to the 555g you'll be glad you did.
sweet.
firefighter321
Member - Posts: 9
Posted: January 12, 2005 at 11:18 PM / IP Logged
Can someone explain to the proper wireing for the remote starter I am installing a mannix sm700. the way I have it hooked is as follows.  If not can you lend a hand and point me in the right direction.  also is the 03 chevy venture a type A, b , c or d key cylinder.
Red to 12v
black to ground
i cut the yellow start wire and connected 87a to the start motor side and 30 to the key side yellow.
I have 86 from the relay going to pink with the blue from the brain.
I have 85 of the relay going to the orange wire from the brain.
and 87 of the relay not hooked up.
firefighter321
Member - Posts: 9
Posted: January 13, 2005 at 8:47 AM / IP Logged
I am looking for the netural safty wire for 03 chevy venture. location and color
firefighter321
Member - Posts: 9
Posted: January 19, 2005 at 11:21 PM / IP Logged
Has anyone got the remote start to work? I installing a mannix sm and I  am haveing so much trouble .  The alarm works good the key is bypassed I removed the bulldog which worked fine so I know the key is bypassed.  When I hook up the wires and try it I get 4 chrips on the remote and nothing.  It's like nothing is comeing out.  Anyone Know which wire goes to where?
