1999 Mazda 626 Alarm
dwahle
Posted: January 05, 2005 at 10:56 AM / IP Logged
Hi all,
I need help in the installation of an alarm with all the bells and whistles.  (Rmote start, windows roll down, alarm, etc) for a Mazda 626 4 cylinder (LX)   If you have any lessons learned, instructions or any advice it would be appreciated.
Dwahle
snguyen
Silver - Posts: 281
Posted: January 05, 2005 at 11:34 AM / IP Logged
Mazda
626
1998-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GREEN
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ WHITE
Ignition #2:
BLACK/ RED
Ignition  #3:
N/A
Accessory:
BLUE
Brake  Light:
WHITE/ GREEN
AT SWITCH ABOVE BRAKE PEDAL **
Tach  Signal:
YELLOW
AT COIL MODULE
Parking Lights:
WHITE/ RED (+)
GREEN PLUG AT FUSE BOX
Headlights:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 ** Brake Wire Also Found In Driver's Kick Panel.
Mazda
626
1998-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK
OEM Alarm Disarm:
Dome  Lights/Superv:
RED / WHITE (-)
AT FUSEBOX
OEM Horn:
Power  Lock:
BROWN / YELLOW (-)
FOUND AT A TAN MODULE NEAR THE HOOD RELEASE
Power  Unlock:
WHITE & BROWN / WHITE (-)
FOUND AT A TAN MODULE NEAR THE HOOD RELEASE***
Trunk  Release:
ORANGE
ABOVE FUSE BOX
Alarm  Input Wire:
RED / WHITE (-)
AT FUSEBOX
Notes:
***The white wire will unlock the drivers door only, and the BROWN / white will unlock the other doors. Use both wires and diode isolate each. See also Note #201 Negative trigger door locks.
dwahle
Posted: January 05, 2005 at 12:42 PM / IP Logged
THanks for the information.
I don't suppose that you have any installation instructions?
Thanks again.
Dwahle
snguyen
Silver - Posts: 281
Posted: January 05, 2005 at 12:45 PM / IP Logged
what are you looking for?
dwahle
Posted: January 05, 2005 at 12:50 PM / IP Logged
Any help or instruction on where to start, and the best way to do it.
THanks!
Dwahle
DiscoKing
Member - Posts: 9
Posted: January 05, 2005 at 5:32 PM / IP Logged
I'm actually in the middle of an install on a 1998.  Connections went pretty smooth.  I started with power connections, then safety cutouts, and then the locks and lights.  The only mix up I made was with the + and - parking light wires.  Keyless entry is working great but I can't get the Remote Start to do anything.  Do you know if the 626 needs an interface module to bypass a transponder?  The salesman told the guy I'm doing this for that he didn't need one but I thought it did.  That would make sense why the system is not doing anything.
DiscoKing
Member - Posts: 9
Posted: January 05, 2005 at 9:32 PM / IP Logged
Thanks for the info.  That didn't work either so I guess I'll have to keep checking wires.  The other funny thing I found was that the hood switch has >1 ohm difference between open and closed.  Does that make sense cause it doesn't sound like enough to me.  Usually switches should have an open reading in one of the positions.
DiscoKing
Member - Posts: 9
Posted: January 08, 2005 at 7:19 PM / IP Logged
Nada.  I get absolutely nothing.  With key in the ignition and the hood switch disconnected nothing happens.  Not even a sound that it is attempting anything.  I have double checked the wiring and can find nothing wrong.  A bit frustrating.  Ugh.
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
