95 Quest HU Question
Bigmaine
Member - Posts: 13
Posted: January 10, 2005 at 4:32 PM / IP Logged
Can someone tell me which harness I need for a new HU. Do I need the one with the amp bypass?
95 Quest HU Question -- posted image. 95 Quest HU Question -- posted image. 95 Quest HU Question -- posted image.
"Intelligence magnifies Ignorance"
Bigmaine
Member - Posts: 13
Posted: January 10, 2005 at 4:37 PM / IP Logged
heres bigger pics since the thumbnails aren't working
stevent
Copper - Posts: 68
Posted: January 10, 2005 at 4:57 PM / IP Logged
You need a ford premium sound harness with bypass plug. You will have to locate the factory amp in the drivers rear cavity and install the bypass plug there.
Bigmaine
Member - Posts: 13
Posted: January 10, 2005 at 5:11 PM / IP Logged
thanx stevent...the amp location would've been my next question.
customsound
Member - Posts: 29
Posted: January 10, 2005 at 10:38 PM / IP Logged
also if you have factory subs, u might want to check into the ford amp integrator harness,  it has level adjust so you can set it like you want it, as far as amp location, look behind the left side trunk lining.
Bigmaine
Member - Posts: 13
Posted: January 11, 2005 at 2:00 AM / IP Logged
the quest i'm working on doesn't have a factory sub...at least i don't think so, but my father's expedition does and i was thinking about using the intergration harness for his.
does anyone know what kinda power that factory amp puts out
customsound
Member - Posts: 29
Posted: January 11, 2005 at 9:04 AM / IP Logged
the ford premium jbl audio has enough power to produce good sound for a 10" pioneer, the pioneer also gives enough magnet clearance in the case that you are replacing the factory sub.
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
