Need help on Disarm wire on 2000 Quest
ma1311
Posted: January 10, 2005 at 6:07 PM / IP Logged
Just install a remote starter on my 2000 nissan quest , I can remote start the car when the door is unlock, and when I remote start the car when the alarm is ARMED (door locked), it will trigger the alarm.
I need help on where is the factory disarm wire (and wire color) located? so I can connect FASD wire from the remote starter to it and disarm the alarm. I try locate in driver side kick panel and has no luck.
any reply and help are great appreciated.
profuse007
Gold - Posts: 2,015
Posted: January 10, 2005 at 6:19 PM / IP Logged
A single pulse on the unlock wire will disarm the factory alarm without unlocking.
Houston,TX
ma1311
Posted: January 10, 2005 at 6:26 PM / IP Logged
Thanks profuse007
is this wire locate in door panel? or somewhere else, do  you know the wire color by any chance? I tryed WHITE/ red, GREEN/ red and had no lock.
Is this wire a small wire or the 12g(?)
thanks again.
profuse007
Gold - Posts: 2,015
Posted: January 10, 2005 at 6:32 PM / IP Logged
its the same wire as the unlock wire. you need to diode isolate the disarm wire from the unlock wire.
|     POWER UNLOCK|RED / black    |- |either door harness        |
Driver's Kick Panel 16 Pin Connector
heres another reference: bulldogsecurity
GREEN/ ORANGE (-) DKPanel
Houston,TX
ma1311
Posted: January 10, 2005 at 7:16 PM / IP Logged
Thanks profuse007
I got info from bulldosecurity b4 I came to this forum, that's how I found out their info and my car is different, I even read thru the book by Haynes (for Mercury & Nissan) and their wiring code is not the same as mine neither.
here is my wiring coloring from my car: ( I actually did the test on all these wires)
Power unlock: GREEN/ brown
power lock: green white
key unlock: WHITE/ red
key lock: GREEN/ red
You see, all these wiring code is totally different. Can you specify by "diode isolate" means?
where else I can locate the FASD wire? I mean bay tracking from setring wheel to DKPanel
Thanks.
profuse007
Gold - Posts: 2,015
Posted: January 10, 2005 at 8:02 PM / IP Logged
does ur lock unlock work?
if it does and youre not using the RED / black for unlock. theres no need for using diodes. just plug it straight on, disarm wire from alram to the redblack.
Houston,TX
