more pats trouble
ucmwp
Member - Posts: 7
Posted: October 22, 2002 at 9:19 PM / IP Logged
Hi.   I have a 1999 mustang saleen and I installed a alarm with remote start. I also got a PKF keyless bypass.  I have tried programming this bypass but the theft light continues to blink.....this is how I have been programming.....key one in the ignition on position until theft light goes out, take it out, put key two in the ignition on position, then put it in the off position, then connect the wire that goes to the bypass output on the alarm to ground and turn the key to the on posistion till the light goes out again......This is what it says to do, however when I take it out, a few seconds later the theft light comes back on and starts to blink again.....HELP PLEASE.
ucmwp
Member - Posts: 7
Posted: October 23, 2002 at 8:49 AM / IP Logged
HELP PLEASE, it started this morning like normal then it just all of a sudden died and the theft light started blinking....I tried to restart it then it was fine and never stalled again....any suggestions on programming this box?
Ohmz
Copper - Posts: 193
Posted: October 23, 2002 at 4:19 PM / IP Logged
whay I remember to program Paths, you need to put key one in to the ignition, turn it to the on position, then take it out and put key 2 in, turn on and then off... take tha key out and remote start the vehicle right away. If your remote start has a bit of a delay and doesn't start right away, use the wire that needs the negative input to make it start right away. This part is very important. The whole process should not take longer than ten seconds.
Platinum - Posts: 12,488
Posted: October 25, 2002 at 10:15 AM / IP Logged
You only have 5 seconds maximum between each step. Are you connecting the wires within 5 seconds after the second key is pulled ?
