Running many leds part 2
djambush
Member - Posts: 39
Posted: October 24, 2002 at 12:58 PM / IP Logged
I read the other post about running more than one led. I still dont think I understand correctly.
I have the regular flashing led that comes with the alarm unit, and I purchased a scanner type and I have 2 more SUPER BRIGHT orange leds. I tried to connect the scanner to the regular LED but nothing happened. It is like it grounded one of them out. What have I done?
It is the Crimestopper 2011 RS.
--Ambush
mikec
Member - Posts: 11
Posted: October 24, 2002 at 10:25 PM / IP Logged
you must use a ground when armed wire for the scanner dioed if you have starter kill relay on board .they will become less bright if more then two l.e.d's are used
Sound Pressure
Silver - Posts: 711
Posted: October 26, 2002 at 2:21 AM / IP Logged
If still a little Running many leds part 2 -- posted image. then check out this link...
http://www.csgnetwork.com/ledresistancecalc.html
Sound Pressure
teknics
Member - Posts: 6
Posted: October 26, 2002 at 12:06 PM / IP Logged
It shouldnt get dim.  Each led is like 1ma.  In theory you can run a bunch off without a diode.  -TeK
MMMMM PoWeR.....need more powerrrrrrrrrrrrrr
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
