Honda Civic EX Coupe RS
Dutton
Member - Posts: 15
Posted: January 15, 2005 at 3:03 AM / IP Logged
I have a compustar remote start and what looking for some help with installing a CM3000 in a honda civic ex coupe.  I have some of the wires figured out, but and confused with the door lock/unlock.  I also have been wondering if i need to buy anything extra to bypass the clutch.  If anyone has any help on DIY for a 96-2000 honda civic please let me know.  I would greatly appreciate any help!
Thanks Dutton
slammedb5
Copper - Posts: 103
Posted: January 15, 2005 at 3:20 AM / IP Logged
Clutch bypass? No. You must, well, I shouldn't say it, but, trick the clutch safety switch... Everytime the clutch is depressed, a signal is sent to the ignition (Clutch depressed, car starts, clutch not depressed, no car start). Fool the ignition into thinking that the clutch is depressed, and you are in businees. Just make sure that you always park your car in neutral.
EK Civic
security
no audio
Acuraxtasy
Member - Posts: 45
Posted: January 15, 2005 at 7:31 AM / IP Logged
Just remember the first time you leave it in gear will be the last time, especially if somebody is standing in front of it.  I wouldn't suggest that ya do it.
Dutton
Member - Posts: 15
Posted: January 15, 2005 at 11:40 AM / IP Logged
The compustar cm3000 is designed for a manual transmission so that it must be set in reservation mode in order to be remote started, so there is no way to leave it in gear if you want to remote start it.  I looked into this before I bought the rs because I have heard so many horror stories.  If anyone can help me with my install of my alarm/rs on my 2000 honda civic ex coupe please let me know.
thanks Dutton
misterjimbo
Silver - Posts: 535
Posted: January 15, 2005 at 11:47 AM / IP Logged
what questions do you have? and just so you know i have a 03 si with an audiovox 996a and whenever i wanna leave work early i put the car in gear and while my boss and i are having a cigarette break i run myself over. who said being careless never helped anyone.
what dont you know about the door locks. what other wires are you unsure of?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 15, 2005 at 1:45 PM / IP Logged
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=1629&product=Remote%20Start#
Heres a tech sheet for the car.....The locks are simple. Actually this whole car is installer friendly
Dutton
Member - Posts: 15
Posted: February 19, 2005 at 2:55 AM / IP Logged
Thanks for all the help everyone, I finally was able to program the remote and it works flawlessly.  Thanks!
