What Amp Would You Recommend For Me?
daddy_yankee
Member - Posts: 8
Posted: January 24, 2005 at 6:55 PM / IP Logged
I currently have 2 12" Rockford Fostgate RFP4412 subwoofers in a sealed box sitting in my closet because I am not sure what kind of amp I should hook them up to.I want the full potential I can get out of the subwoofers in my Civic hatchback. When it comes to car audio, I don't know much. Here are the specs on the subs:
Nominal Power Handling - 200 Watt
Peak Power Handling - 400 Watt
Frequency Respond - 28 Hz - 400 Hz
Sensitivity - 88 dB
Impedance - 4 ohm
Woofer Material - Poly / Plastic
Surround Material- Foam
Enclosure- Non-Enclosed
Top Mounting Depth- 5.75 In.
Thanks, I would really appreciate it.
pimpincavy
Silver - Posts: 880
Posted: January 24, 2005 at 9:33 PM / IP Logged
If you can find a JBL 600.1 buy it, they are great amps but can be hard to find b/c JBL doesnt make that line anymore.    If you cant find the JBl check out ikesound.com, the have usually have good deals on amps, I know they have a Orion 600D for pretty cheap. The Memphis Power Reference 500W amp would be a good choice to.
daddy_yankee
Member - Posts: 8
Posted: January 24, 2005 at 10:37 PM / IP Logged
Would this Sony amp work for me?
Key Features:
» 200 watts RMS x 2 at 4 ohms
» 250 watts RMS x 2 at 2 ohms
» 500 watts RMS x 1 at 4 ohms
» stereo or bridged mono output
» Tri-way capable (Tri-Way Crossover required)
» requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
» MOSFET power and output stages
» preamp- and speaker-level inputs
» preamp outputs
» gold-plated connectors
» variable low-pass crossover (50-300 Hz, 12 dB/octave)
» variable bass boost (0-10 dB at 40 Hz)
» 15-3/4"W x 2-3/16"H x 10-7/8"D
» warranty: 1 year
jeffchilcott
Platinum - Posts: 2,483
Posted: January 25, 2005 at 12:01 AM / IP Logged
yes It will work just fine.   Not as clean as the JBL amp recomended above but will work fine for your aplication
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Alpine Guy
Platinum - Posts: 2,478
Posted: January 25, 2005 at 1:06 AM / IP Logged
If you get that amp, make shure to hook it up in stereo.  It will fry the amp if you bridge it.
Mb Man
Posted: January 25, 2005 at 2:08 AM / IP Logged
how about a phoenix gold  x 200.2 it would give ya 200 rms x 2 all day long,,,,,,,,,,,
eclipse cd8454,mb quart psc216"s mb quart pce 216"s,pg xs 6600,ss van gogh 600.2,ss eg10x subs,(4) ss tarantula 6x9"s,2002 ford ranger edge,,
wheelerdr
Copper - Posts: 337
Posted: January 25, 2005 at 4:33 AM / IP Logged
I would only recomend that amp if that all the money you have for an amp or it is given to you. how much money do you have to spend on an amp
daddy_yankee
Member - Posts: 8
Posted: January 25, 2005 at 7:21 AM / IP Logged
I have about $300-400cdn to spend on an amp for my subs.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
