Sub box Question
Sancho
Copper - Posts: 162
Posted: January 24, 2005 at 10:31 PM / IP Logged
Is it really big difference that my sub box port tuned to 30hz but recommendation was to tune it to 28hz?
Thank you
Head Unit:Alpine CDA 9835
6.5 MB Quart Pce 210
Amp:JBL 80.4
Amp:JBL 1200.1
Sub:Adire Brahma 12 MKII
stevdart
Platinum - Posts: 5,816
Posted: January 24, 2005 at 10:47 PM / IP Logged
No, not at all.  If what you say is the the true tuning, you've got it closer than most do.  Too, I've seen recommendations for tuning very often relying on the box size and port size that will easily fit a vehicle, but are not the best tuning for the particular woofer.  For example, I've seen 35 Hz as the recommended tuning, but in real life, a tuning point of 26 Hz made for better sound.  What are you using for design help, any software?
Sancho
Copper - Posts: 162
Posted: January 24, 2005 at 11:01 PM / IP Logged
i'm using winisd...by the way do know about jbl speakershop or is this an old programm?
Amp:JBL 80.4
Amp:JBL 1200.1
stevdart
Posted: January 24, 2005 at 11:09 PM / IP Logged
I've heard both haemphyst and DYohn say it was a great program.  In fact, haemphyst used it to design a crossover for me for a project I was working on.  Yes, I heard it is an old program, and you may have to enable settings on Windows XP to run it.  Anything old I try, though, XP figures the settings automatically.
haemphyst
Platinum - Posts: 5,059
Posted: January 25, 2005 at 1:02 AM / IP Logged
If you have a copy of JBL Speakershop, don't lose it... it is the only software I use. GREAT software package. I modify the database by deleting all of the old, decrepit drivers as soon as I install it - makes for a little smoother database access. As far as running on XP, it works fine, but do not try to change window resolution on it while running - it'll puke all over you! Does the same in 2K. Change the default resolution under the option menu, restart the program, and it'll work just fine.
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
