cd8545
Alpine Guy
Platinum - Posts: 2,478
Posted: January 26, 2005 at 2:41 PM / IP Logged
I have an option to buy a Eclipse CD8545 brand new, but not from an authorized dealer.  Will i loose out on the Eclipse security because i don't purchase it from a dealer?  And will i have full access to the E-iSERV to set it up over the computer? Obviously i wont get a warranty.
Alpine Guy
Posted: January 26, 2005 at 7:35 PM / IP Logged
no one knows?
Alpine Guy
Posted: January 26, 2005 at 10:07 PM / IP Logged
common now, i don't bite
stevdart
Platinum - Posts: 5,816
Posted: January 26, 2005 at 10:21 PM / IP Logged
I don't know but I'll take a guess so you won't feel so ignored....
The deck has a serial number, so you should be able to get security set up and use the software online to make the adjustments.  As long as that serial hasn't been used by someone else.  But of course I'm an unauthorized opinionator....and am only guessing.
Master Asylum
Silver - Posts: 400
Posted: January 27, 2005 at 7:02 AM / IP Logged
That's a good question Alp, I am going up to StereoinDash today to get my deck swapped out(This one is having some power issues for no apparent reason and it's annoying to reset daily). I'll ask them up there is they know anything about the extent of the security and server use.
1998 Monte Carlo w/
Eclipse CD8454
2xRockford 5.25" Power 2-way T152C
2xRockford 6"x9" Punch 3-way FRC4369
1xMemphis 16-MCH1300 5-channel
2xKicker 12" L5 Solobaric-2 Ohm
Alpine Guy
Posted: January 27, 2005 at 11:56 AM / IP Logged
thanks Master Asylum , your a good guy.
forbidden
Platinum - Posts: 5,354
Posted: January 27, 2005 at 1:13 PM / IP Logged
No warranty, no theft replacement. You should stil be able to use the ei-serve. You may have to fill out a ESN change of owner certificate to register you as the new user.
Alpine Guy
Posted: January 27, 2005 at 7:56 PM / IP Logged
so its useless to save the money if i can't get that change of owner certificate.
forbidden
Posted: January 27, 2005 at 8:17 PM / IP Logged
Even if you did get the change of ownership certificate, there would still be no warranty in Canada.
