98 Grand Prix, alarm/remote start
tdmiller
Posted: January 26, 2005 at 9:33 PM / IP Logged
I have a Prestige Platinum  Model APS786T Alarm remote starter that Iam tring
to install.Have all working except tach pick up. Have tried Pin 8,conn.2 @pcm White wire
Have not had any luck, Also check a PURPLE / white wire as well.
any help would greatly appreciate Thanks
Moderator - Posts: 12,488
Posted: January 27, 2005 at 11:28 AM / IP Logged
When you "checked" them, how did you have your DMM set ? Make sure that your in AC mode and that you have the target wire on the BLACK lead and 12 volts constant on the RED lead. As you press the accelorator, the voltage rises with the RPM's.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
