791xv in an Envoy
xxmattfxx
Copper - Posts: 57
Posted: January 31, 2005 at 8:06 PM / IP Logged
I plan to install the Viper 791xv in an envoy next weekend, along with a PLDATA-III from crimestopper, and the 455g from dei.  I've read through the forum but haven't seen much in regards to adding an aftermarket alarm, to replace the existing factory alarm. I am pretty sure it is an SLT so I should be able to disable it.  Does anyone have any more detail in regards to which wires on the 455g I should use, and which I should wire traditionally...e.i. the door triggers, domelight...etc. Thanks
italnpimp59
Silver - Posts: 427
Posted: January 31, 2005 at 10:19 PM / IP Logged
what year envoy?
xxmattfxx
Copper - Posts: 57
Posted: February 01, 2005 at 3:56 PM / IP Logged
sorry, I believe it's a 2002
kgerry
Platinum - Posts: 3,455
Posted: February 01, 2005 at 5:11 PM / IP Logged
455G should do everything for you.... just hook it up like the instructions say and off you go.... it will do locks, arm/disarm and dome....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
xxmattfxx
Copper - Posts: 57
Posted: February 02, 2005 at 9:47 AM / IP Logged
ok, I am skepticle because I seem to remember reading in other posts that wiring the trigger to the 455g created an interference and the arm would not work correctly because the dome light would still be on, or something of that sort.
kgerry
Posted: February 02, 2005 at 10:41 AM / IP Logged
the 455 holds back the domelight for 10 seconds from the alarm... allowing it to shut off before making a connection to the alarm circuit... it works fine most of the time.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
xxmattfxx
Copper - Posts: 57
Posted: February 02, 2005 at 11:19 AM / IP Logged
some other things, does the 455g take into account the hood and trunk triggers individually...so that they show up correctly on the 791xv lcd remote?  I see some listings for a factory hoodpin switch in the wiring charts, is this on all models or just certain envoy's?
kgerry
Posted: February 02, 2005 at 12:59 PM / IP Logged
hood and trunk have nothing to do with the 455
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
