compustar artic start programing
repmud
Copper - Posts: 54
Posted: January 31, 2005 at 8:21 PM / IP Logged
It's a 1WAM-s. I am getting tired of hearing the horn honk all the time, thinking of disconecting the horn wire. Is there anyway to program the thing to beep only when I lock the door? I do not want to hear the thing everytime I unlock the doors and trunk, as well as activate the remote start.
I was thinking of wiring the horn so it powers off of the door lock pulse/relay, after I disconect the wire from the brain to the horn, if I can not program the unit to do what I want. Can I do this? the car is an 02 Cavalier
Moderator - Posts: 12,488
Posted: January 31, 2005 at 9:02 PM / IP Logged
Cut the wire off the HORN output of the 1WAMS and attach the side that is attached to the horn to pin 30 of a SPDT relay. 87 will go to ground and 86 you will need to split a wire off the BLUE/BLACK wire of the 1WAMS ( one to lock output and the other to this pin ) and then 85 will go to 12 volts constant. 87a will not be used.
repmud
Copper - Posts: 54
Posted: February 01, 2005 at 9:48 AM / IP Logged
Thanks for the input, the horn function is driving me nuts.
Posted: February 01, 2005 at 9:50 AM / IP Logged
No problemo compustar artic start programing - Last Post -- posted image. I never use the horn function on any of these units. Customer's never even ask for horn confirmation around here, the lights are a good enough indication for lock/unlocking.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
