300c Auto headlamps
Most Wanted
Member - Posts: 27
Posted: February 02, 2005 at 3:23 PM / IP Logged
i have 1 coming in and the customer says he was told other places they will not work.
i did a search and came up with they will if you goto a bulb, But other ways they will not work.
So whatrs the deal?
mxxmikexx
Silver - Posts: 796
Posted: February 02, 2005 at 4:00 PM / IP Logged
are you talking about the 2005 chrysler 300?
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Most Wanted
Member - Posts: 27
Posted: February 02, 2005 at 5:31 PM / IP Logged
yea
auex
Platinum - Posts: 5,041
Posted: February 02, 2005 at 6:28 PM / IP Logged
If the car has HID then don't mess with it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mxxmikexx
Silver - Posts: 796
Posted: February 02, 2005 at 8:16 PM / IP Logged
DEI tech says negative trigger parking lites, WHITE/ brown at switch or cluster, gray 26p plug, pin 3 Parking lights are negative trigger thru an 1,670 ohm resistor. There is a rest resistance on the wire, so must use a relay to isolate from the switch.
doesnt say anything specific about the autolamps, so i dont know. you can try calling audiovox tech if you want , check your private message
Mike Battaglia
JWorm
Platinum - Posts: 2,208
Posted: February 03, 2005 at 12:51 AM / IP Logged
My shop has only done a couple 300c. I didn't do any of them personally, but I remember one customer complaining her autolamps didn't go on when remote started at night. I believe the parking light wire was was isolated with a relay with the resistor DEI specified. We never were able to figure out why.
mxxmikexx
Silver - Posts: 796
Posted: February 03, 2005 at 1:55 AM / IP Logged
so whats the deal then? once you remote start the vehicle you have to shut it down and then restart it with the key to get the auto lites to come back on?
Mike Battaglia
Most Wanted
Member - Posts: 27
Posted: February 04, 2005 at 10:35 AM / IP Logged
well i didnt get to the bottom of it cause i had to send it to the interior shop to get some stuff done.
what im thinking is im gonna try Not hooking the Parking lights up and see if they will work auto, If they do then start playing and seeing what i can come up with.
It really wont matter if i do hook up the Prk Lights cause it is a 2 way system.
The customer says he doesnt want the rem start if the auto lamps wont work, so  ill keep you updated
JWorm
Posted: February 06, 2005 at 12:56 AM / IP Logged
I would refuse the job. If he expects you to install the system and then remove it if the autolamps don't work, then he is the type of customer that will complain about anything and everything. Is he that lazy to turn on the lights once he gets in the car?
I don't know if the autolamps work once you get in the car. I have just seen it when you remote start the car at night and the autolamps don't turn on. Personally, I wouldn't want my headlights turning on when I remote started my car.
Most Wanted
Member - Posts: 27
Posted: February 07, 2005 at 3:25 PM / IP Logged
Im sorry i wont refuse my customer, then he thinks that im not the person he should be going to for his work.
when i get the car back from the interior shop ill see about the lights, ill try it without hooking up any lights, then ill try with +12 to a bulb and see what works, there has to be a way this works.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
