Tach wire on 98 galant
avitalsuxs
Posted: October 29, 2002 at 8:21 PM / IP Logged
I have avistart 6000 will not except tach wire on distributer.  It needs to be between 1-5 volts, tach is less than 1 volt.  No tachless mode on alarm.  Is there anyware else that I can find a wire for rpm's that will work?
securinu
Silver - Posts: 772
Posted: October 29, 2002 at 8:26 PM / IP Logged
go to any odd color injector wire. this should work just fine
Player69
Silver - Posts: 504
Posted: October 29, 2002 at 8:31 PM / IP Logged
Are you using the white wire at the coil?
avitalsuxs
Posted: October 29, 2002 at 8:34 PM / IP Logged
yes
asfdn
avitalsuxs
Posted: October 29, 2002 at 8:37 PM / IP Logged
Ill tell you what it is doing.  It will start car, the starter doesnt shut off for a few seconds,  When it does engine will shut off and then it tries 2 more times
asfdn
avitalsuxs
Posted: October 29, 2002 at 8:40 PM / IP Logged
it starts but the starter doesnt shut off for a few seconds when it does the engine shuts off
asfdn
Player69
Silver - Posts: 504
Posted: October 29, 2002 at 9:00 PM / IP Logged
Not good.  It definately sounds like you are not getting a tach signal.  You can try and find an injector wire like securinu suggested or get a different remote start.
jiggabo4u
Member - Posts: 17
Posted: October 29, 2002 at 9:03 PM / IP Logged
maybe you shouldn't of bought a pos galant!!!
Platinum - Posts: 12,488
Posted: October 29, 2002 at 9:54 PM / IP Logged
Did you verify the correct tach signal and also double check the tach programming sequence of the RS unit ? How did you get a reading of 1 volts on the DMM ? Please explain it so it will help us better understand what you did so we're not chasing our own tails .
Sound Pressure
Silver - Posts: 711
Posted: November 01, 2002 at 2:10 AM / IP Logged
Did you set your DMM to AC?
Sound Pressure
