factory arm/disarm wires?
mikk
Member - Posts: 35
Posted: February 06, 2005 at 8:02 PM / IP Logged
could the factory arm(lock) / factory disarm(unlock) wires be used to trigger my door locks? b/c the door locks/unlock wires arent currently working on my ultra start 4255 for some reason. seems the wires(factory) should be able to trigger the relays/locks, right?
mikk
mo12v
Posted: February 06, 2005 at 8:16 PM / IP Logged
Year & Make of Vehicle?????
MO
Uniqueauto
Copper - Posts: 73
Posted: February 06, 2005 at 8:17 PM / IP Logged
Need Car info?
jrilla
Gold - Posts: 1,498
Posted: February 06, 2005 at 8:20 PM / IP Logged
No you wouldn't want that. There are seperate door lock outputs on that unit that you would use to control the locks. Depending on what vehicle and type of locks, you may need relays. There are only negative lock outputs on that unit.
J Rilla
Owner/Installer
mikk
Member - Posts: 35
Posted: February 06, 2005 at 8:29 PM / IP Logged
' 94 pontiac bonneville. vehicle  has postive door locks and since the door lock wires arent working what  other choice(s) do i have? yes, relays will be  required.
mikk
jrilla
Gold - Posts: 1,498
Posted: February 06, 2005 at 8:40 PM / IP Logged
If the lock outputs don't work, then you need a new unit if you want the locks to work. If that is the problem.
J Rilla
Owner/Installer
swamprat323
Gold - Posts: 1,335
Posted: February 06, 2005 at 8:42 PM / IP Logged
Did you put fuses on the relays if so are they good. Also how did you hook the relays.
mikk
Member - Posts: 35
Posted: February 06, 2005 at 10:14 PM / IP Logged
lock outputs do not work. so i was gonna try the factory arm/re-arm wires. there is an inline fuse to all relays-its fine. hook'd them up according to the diagram for my(+) lock type. just got the unit few days so a replacement is possibly. if not- than i'll try those wires and believe it should work.
mikk
jrilla
Gold - Posts: 1,498
Posted: February 06, 2005 at 10:16 PM / IP Logged
Your doors will unlock when you press start.
J Rilla
Owner/Installer
mikk
Member - Posts: 35
Posted: February 07, 2005 at 11:26 PM / IP Logged
yes, you are correct. i found that out when i hit start. getting a replacement unit soon. would you know how to hook up dashmount led to this unit or domelight supervision - dont see any wires for those features.
mikk
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
