Do I need a second battery?
dasmodul
Member - Posts: 34
Posted: February 08, 2005 at 4:03 PM / IP Logged
Going to be running (in a 2002 Golf TDI):
1) Rainbow 3-way Vanadium Components (Front)
2) Arc Audio ACS 265 Components (Rear)
3) Arc Audio XXK 4150 Amp. (For all components & Deck)
4) Alpine CDA-9855 Deck
5) JL Audio 10" Stealthbox
6) Arc Audio KAR 900.1D Mono Amp. (For Sub)
My dealer is recommending I get a Stinger battery and a relay for the setup. Do I really need it?
Ravendarat
Platinum - Posts: 2,806
Posted: February 08, 2005 at 4:47 PM / IP Logged
Replacing the battery under the hood with a stinger battery isnt a bad idea but a second battery is only nessasary if you are A) going to be running the stereo with the car off or B) if you are competing in a class the dictates that the car is driving in and out of the lanes but cannot be running while competing, if your car wont start after you run then you can very well drive it away. I think an upgraded altenator is what you should really be looking at.
supradude
Silver - Posts: 915
No, I wouldn't say that you need it for that setup.
'85 Toy
dasmodul
Member - Posts: 34
Posted: February 08, 2005 at 4:56 PM / IP Logged
His recommendation wasn't to replace the car battery, it was adding a second, auxillery one. He was insisting I need it so I thought I'd ask around.
Alternator upgrade? How much do those babies go for?
forbidden
Platinum - Posts: 5,352
Posted: February 08, 2005 at 5:19 PM / IP Logged
Say no to the second battery issue. Ravenderat is bang on with his recommedations. All the second battery is going to do is put more of a strain on the tiny little alternator that you already have.
audiobass10
Silver - Posts: 328
Posted: February 08, 2005 at 5:27 PM / IP Logged
Get a new alt..period...mind if i ask why you're running components in the rear?
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
dasmodul
Member - Posts: 34
Posted: February 08, 2005 at 5:37 PM / IP Logged
Thanks. As for why components in the rear, my golf came with components both in the front and rear and so I am just going to replace the cones inside with better ones for not tearing up the door's sake. I used to have a Civic and was fond of putting high quality coaxals in the back, but can't in this car.
audiobass10
Silver - Posts: 328
Posted: February 08, 2005 at 5:40 PM / IP Logged
Just to let you know..sq wise..it would probably sound better with just a front stage..but its ur call man.
Dave
15" Kicker CVR
Profile AP1000M
It's Loud
Ravendarat
Posted: February 08, 2005 at 6:43 PM / IP Logged
I understand that he was suggesting that you add a second battery, what I  am suggesting is that you replace the stock battery with the stinger one and get a high output altenator. Check around on ebay and hit up google, you should be able to find something, as for price it all depends on the size you want, check around  alittle bit.
audiobass10
Silver - Posts: 328
Posted: February 08, 2005 at 7:09 PM / IP Logged
agreed^^that is your best choice overall
Dave
15" Kicker CVR
Profile AP1000M
It's Loud
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
