Remote Starter
juanpito
Member - Posts: 43
Posted: February 10, 2005 at 1:30 PM / IP Logged
My remote start on my car doesn't start when on car sit over night only when the car is warm. Did miss a wire connection somewhere.
Nissan Altima 96 GXE.
Juan67
kgerry
Platinum - Posts: 3,455
Posted: February 10, 2005 at 1:33 PM / IP Logged
did you hook up the cold start starter wire as well?   most Nissans have 2 starter circuits....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
thepencil
Gold - Posts: 1,526
Posted: February 10, 2005 at 1:48 PM / IP Logged
"Also known as the cold start wire. As with the starter wire, it changes state only when the key switch is held in the start position, but is not connected to the starter motor. Interrupting this wire will not prevent the starter motor from spinning. This wire needs to be activated only when adding a remote start, and must be activated only while the vehicle is starting."
Second Starter wire is blk/grn to blk/yel +   at the ignition harness.
Also, don't forget to set the jumper on your remote starter unit to 2nd starter.
Be careful whose advice you buy, but be patient with those who supply it.Remote Starter -- posted image.
juanpito
Member - Posts: 43
Posted: February 10, 2005 at 2:13 PM / IP Logged
What do you mean by
(Also, don't forget to set the jumper on your remote starter unit to 2nd starter. )
Juan67
thepencil
Gold - Posts: 1,526
Posted: February 10, 2005 at 2:35 PM / IP Logged
Depending on the type of starter unit you have. If the unit has an extra high-current output you can use it to power a 2nd IGNITION or a 2nd ACCESSORY or a 2ND STARTER WIRE. Setting the jumper will allow to you to do the choice that I mention without having to run a seperate relay.
juanpito
Member - Posts: 43
Posted: February 11, 2005 at 5:58 AM / IP Logged
OK I got it. Thanks once again....
Juan67
juanpito
Member - Posts: 43
OK I got it. Thanks once again....Remote Starter -- posted image.
Juan67
