Pros and Cons of an Amp Under a Seat
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 16, 2005 at 8:00 AM / IP Logged
I've never had an amp die due to vibration. AND I drive drunk all the time. Like I said vibration may effect an audiobahn but out of probly 10 alpines mounted on a box none of them have die. But I agree the risk is there. Also if people would just bolt there speaker box down they wouldn't have to worry about anybody running away it. Most theives don't carry a battery drill and won't spend the time taking out 8-12 screws for a speaker.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
skoldspuppy
Silver - Posts: 342
Posted: February 16, 2005 at 9:18 AM / IP Logged
Ok Since I'll just run an extra 3 feet of wire for each wire to the amp an just mount it on the back of the seat, at least with the extra wire I can fold my seat down when needed to haul something
oonikfraleyoo
I also never had an amp die because its mounted directly to the box, but I guess theres a first for everything
Later
Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
Paradigm
Silver - Posts: 284
Posted: February 16, 2005 at 9:30 AM / IP Logged
The only way to truly keep an amp from failing due to vibration would be to encase it in a force field or set it up to act as some sort of hover craft that only moves with an envelope of air and never bumps into anything. Regardless of where you mount an amp, it is going to be subjected to vibration. Your car vibrates with the engine running, doesn't it (I know this is minimal, but I'm trying to ilustrate my point, so bear with me)? True, mounting it directly to the sub box may cause it to fail prematurely, but if that is one of the only spots you have to mount it, I'd say go for it. As someone mentioned previously in this thread, most newer amps (I would like to think) would be made stout enough to handle such vibration, except in extreme cases of the box flexing/vibrating. And of course, since most of you advocate building custom enclosures and bracing heavily to reduce/eliminate said vibrations, then you should be even safer. A prefab box - that would be a tougher case. But I really don't see a problem with mounting directly to the box otherwise (except for the theft part mentioned, that really would suck!).
VEHICLE: 2002 GMC Sonoma ZR2
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
JL Audio 10W6 (originals) x3
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
Paradigm
Silver - Posts: 284
Posted: February 16, 2005 at 9:34 AM / IP Logged
The only way to truly keep an amp from failing due to vibration would be to encase it in a force field or set it up to act as some sort of hover craft that only moves within an envelope of air and never bumps into anything. Regardless of where you mount an amp, it is going to be subjected to vibration. Your car vibrates with the engine running, doesn't it (I know this is minimal, but I'm trying to illustrate my point, so bear with me)? True, mounting it directly to the sub box may cause it to fail prematurely, but if that is one of the only spots you have to mount it, I'd say go for it. As someone mentioned previously in this thread, most newer amps (I would like to think) should be made stout enough to handle such vibration, except in extreme cases of the box flexing/vibrating. And of course, since most of you advocate building custom enclosures and bracing heavily to reduce/eliminate said vibrations, then you should be even safer. A prefab box - that would be a tougher case. But I really don't see a problem with mounting directly to the box otherwise (except for the theft part mentioned, that really would suck!).
Sorry for the double post - had to fix some things to make things clearer. Pros and Cons of an Amp Under a Seat - Page 2 -- posted image.
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
fastone
Copper - Posts: 83
Posted: February 16, 2005 at 9:57 AM / IP Logged
[QUOTE=oonikfraleyoo]....... AND I drive drunk all the time. ............
Are you a) kidding or b) and idiot?
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 16, 2005 at 2:39 PM / IP Logged
Well I never drive drunk. I dont even drink. But if I said I wasn't an idiot someone would probly make a good argument against that so I won't.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
customsuburb
Gold - Posts: 1,813
Posted: February 16, 2005 at 4:42 PM / IP Logged
I vote for the back of the seat mounting. You can mount it low on the seat so that you don't have to have much extra slack in wire to fold the seat down. Kinda like this... https://www.the12volt.com/installbay/forum_posts.asp?tid=33362&KW=defective (look at the last pic)
skoldspuppy
Silver - Posts: 342
Posted: February 16, 2005 at 7:35 PM / IP Logged
Yeah that looks nice, thats what Im going to do, now I just need to get me some MDF and screw it into the seat frame and Im good, you think 5/8 MDF would be good enough or kick it up to 1 inch
--Skold
4 Fosgate T152C
