Removing the console
sundownernz
Member - Posts: 10
Posted: February 22, 2005 at 6:46 PM / IP Logged
Hi all. Been checking out this forum for a while now but this is my first post. Awesome site by the way.
I'm looking at building a system into my van and have checked out the Alpine site and how they build those cool interiors. Before I rip into my van I thought i'd clarify a few things first. I notice when creating the consoles etc to fit the donor car they tend to lay down masking tape, then glue aluminium foil to the tape. With the mdf cut they then glue this to the foil and layer up with cloth, glass, resin and bog ontop of the foil. When removing the part from the car for finishing, where does it part from the vehicle? The tape is stuck to the car, the foil glued to the tape and the mdf glued to the foil along with the fibreglass etc. I assume it parts at the foil/mdf interface but can anyone clarify this for me before I rip into my project and find I can't get the part out. And how difficult is it to get the piece to part from the vehicle?
Many thanks and hope to post some pics as I progress.
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 22, 2005 at 11:44 PM / IP Logged
Are you gonna have both glass and MDF touching the foil? If yes then the foil and/or some tape will come up and you'll probly end up picking some of it off your glass. If not then you really don't need the foil and tape. Just a tarp or garbage bag to keep resin from touching anything it ain't 'post to. DO NOT let resin get on anything you don't want it permenatly attached to.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
realitycheck
Silver - Posts: 751
Posted: February 23, 2005 at 8:30 AM / IP Logged
I think he might be asking how they seperate the glass piece from the mdf frame they have!  Im not really sure though,  Can you elaborate a little more there sundown and let us know more of what you're asking???
sundownernz
Member - Posts: 10
Posted: February 23, 2005 at 4:10 PM / IP Logged
Sure. In the Alpine pics and articles they show a number of layups on dash boards, doors etc that have masking tape put down first direct on the vehicle, then aluminium foil glued to the tape. They then in some cases super glue MDF to the foil or glue the speaker cloth to the foil then glass over this. My question is with the tape stuck to the dash, the foil glued to the tape and the MDF/cloth/glass either glued or bonded to the foil as well, how difficult is it to get whole part to seperate from the dash to get it out for finishing? I assume that the bond between either the tape/foil or the glued MDF/cloth/glass etc to the foil is weak enough to split away at the foil and you would end up with some foil stuck to both the part and the tape to be removed when cleaning up the part and vehicle. However I would have thought that there is no reason to glue the foil to the tape as it should hold in place as you form it over the countours of the vehicle, then the part would just seperate at the foil/tape interface.
The way they seem to do it is they have each layer stuck to the one below, so where does it seperate and how difficult is it to get the part out of the car?
Thanks for your help.
Garry
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 23, 2005 at 7:46 PM / IP Logged
I don't glue the foil to the tape. I tape it to the tape. The foil is really only to be extra sure that nothing goes through the tape. You do however want to secure it in some way because it will slide while your working. Both will come up. In some places just foil in some places foil and tape. On a good day it should be pretty easy to remove. Depending on the particular part your making and how you do it, it can be a pain. If you don't cover the dash completly it might not come up at all. But I'm sure you can handle it.
Also you said "in some cases super glue MDF to the foil" I would use hot glue not super glue.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
sundownernz
Member - Posts: 10
Posted: February 24, 2005 at 3:45 PM / IP Logged
Hi Nik,
Thanks for the advice. You confirmed the way I was thinking and thats reasuring. Next step is to rip into it so will keep you posted on progress.
Many thanks,
Garry.
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 24, 2005 at 7:20 PM / IP Logged
No prob man. Keep us updated.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
realitycheck
Silver - Posts: 751
Posted: February 25, 2005 at 7:43 AM / IP Logged
Hey Garry are you going to post us up some pics man?   I'd like to see how it all turns out!
sundownernz
Member - Posts: 10
Posted: February 27, 2005 at 10:02 PM / IP Logged
Hi Realitycheck,
Sure will. It may take a while as I have a few things to sort out first and some more hardware to buy (17" LCD TV etc) but should be on to it within the next month or 2.
Garry.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
