adding powered sub to factory stereo
bad_az_s10
Member - Posts: 8
Posted: February 26, 2005 at 9:22 PM / IP Logged
ok I searched for about two hours and couldn't find exactly the answer I was looking for so I am just going to ask....I was once told that if  I run an amplifier's High input in parallel to lets say in this case the rear speakers on my deck that the head unit would not see any harm from the added load...so Again the question is basically can I splice into my rear speakers to get a high level signal for my amplifier without harming my factory deck or losing output from my rear speakers?...Thank you in advance for your help on htis matter.
Trucks, Sex, And NO REGRETS!
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 26, 2005 at 9:30 PM / IP Logged
The answer to your question is yes. But I have a sneeking suspition that your are attempting to hook it up using the outputs on the amp. DO NOT do this. You have to hookit in through the speaker level inputs of the amp. If your amp doesn't have speaker level inputs, you'll need to get a line level converter.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
bad_az_s10
Member - Posts: 8
Posted: February 27, 2005 at 10:38 AM / IP Logged
no i most definately wasnt going to do that i was talking about using the high level inputs on the amp... thank you for you quick response.
Monday, September 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
