2001 Honda Civic Diagram (Alarm)
sador
Copper - Posts: 57
Posted: April 28, 2002 at 8:52 PM / IP Logged
Does the 2002 Honda Civic diagram the same of the 2001?
If is not can you help me to get the 2001 civic diagram.
Platinum - Posts: 12,488
Posted: April 28, 2002 at 9:39 PM / IP Logged
Honda
Civic
2001-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK / YELLOW
Ignition #2:
BLACK/ RED
Ignition  #3:
N/A
Accessory:
WHITE/ RED
Brake  Light:
WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE
IN 2-PIN PLUG AT PASSENGER SIDE OF BATTERY
Parking Lights:
RED / BLACK (+)
AT BACK OF FUSE BOX
Headlights:
BLUE/RED (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
n/a
Notes:
 * This vehicle is equipped with a transponder immobilizer system
Honda
Civic
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
SEE NOTE BELOW
OEM Horn:
ORANGE (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ BLUE (-)
GRAY PLUG ABOVE DRIVER'S KICK PANEL
Power  Unlock:
WHITE/ GREEN (-)
Trunk  Release:
N/A
Alarm  Input Wire:
SEE NOTE BELOW
Notes:
** The Driver's Door Trigger Is Green (-), Front Passenger Door Trigger Is Lt. GREEN/ Red (-), Rear Doors Trigger Is GREEN / WHITE (-). The Wires Are Found In The Alarm Plug In A Green Plug Above The Driver's Kick Panel.
sador
Copper - Posts: 57
Posted: April 29, 2002 at 5:35 PM / IP Logged
Thank you Jeff
 Also you was helpping me with my Remote Starter but I can't find the problem so what I did is take everything off and I gonna try to sell it  because that only thing  it work is the alarm  and then I gonna buy another brand maybe like one a those that you have on your website.
  Sador
Posted: April 29, 2002 at 5:42 PM / IP Logged
Just contact me via email and I will hook you up with a sweet deal.
Tuesday, May 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
