2003 Camry Alarm/Starter need Help
Jax0408
Posted: November 04, 2002 at 4:22 AM / IP Logged
I am putting a Clifford Solaris Alarm in a 2003 Camry LE.  I was wondering if anyone might have possibly put an alarm with remote start in this type of car?  First off when I disarm alarm dome light does not light up.
2. Does anyone know why I can not get the remote start to work I have the ignition wires hooked up and the accesory and tach but it will not even try to crank I tried to program but parking lights will not come on to say it accepts program.  Is there something special with the camrys that I am missing?
Any help would be greatly appreciated thanks JIM
cpgoose
Gold - Posts: 1,098
Posted: November 04, 2002 at 7:37 AM / IP Logged
1.  For the dome light, I'm not sure how your alarm works...but for mine I had to:
  •  Install a relay to make the domelight supervision work.  The relay was hooked up to (1)power, (2)ground, (3)the alarm's BLACK/ white wire, and (4)the door input wire.
Do you have to do all of that (install a relay)?
2.  For the remote start, you said you have the ignition and accessory wires all hooked up, but you didn't mention any power wires.  You should have a couple power wires from the relay satellite that need to be hooked up to 12v+.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 04, 2002 at 7:50 AM / IP Logged
and you never mentioned starter wire did you connect your starter out put up? also there is a transponder that needs to be bypassed for remote start to work.
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
