valet remote start model 551t
tabo
Member - Posts: 27
Posted: November 07, 2002 at 6:39 PM / IP Logged
Anyone ever installed the "VALET REMOTE START MODEL 551T" its made by dei...  is it any good?  anyone have wiring diagrams for this or install diagrams?   thanks   I know its a "addon" to my stock alarm..
tabo
djfearny2
Silver - Posts: 810
Posted: November 07, 2002 at 7:36 PM / IP Logged
i use dei add ons all the time they are good check this out
primary harness
black -ground ,  WHITE/ blue -negative activation input. , lt GREEN/ black - factory disarm, yellow -output to security system , this wire must be connected to the ignition wire of current alarm instead of the alarm being connected to the cars ignition wire , if you dont do this the alarm will not work right while in remote start mode such things like door locks.  white- negative light flash output  if you want to opperate lights you need to convert this to possitive using a relay like this pin 87a not used. pin 86and pin 87 constant fused 12 volts pin 30 output to parking light wire. grey/black wait to start  (for deisel engines.)
heavy guage relay satelite wires
reds - 12 volt constant , pink- igniton one,  purple- starter wire, orange - accesory wire. pink/white- second igniton  or if no second ignition is needed than you can use this as your light flash output wire instead of white wire after relay.
6 pin harness:  blue- not used  blueblack- not used . grey hood pin switch not neccesary but this wire can not see ground, if you want to remote start, violet /white  tach wire needed or timed remote start is neccesary. brown- wire possitive brake shut down.  BLACK/ white  neutral safety this wire must see ground in order for the remote start to work . word of advise , ground it permenantly.
or http://www.directed.com/guides/pdfs/N551T.pdf
acrobat reader is required.
Jon
Installer/Help Technician
---coral springs florida---
tabo
Member - Posts: 27
Posted: November 08, 2002 at 2:33 AM / IP Logged
thanks for your quick response you're the best!    one question..  can i use the remotes that come with it?  or do i still use my original remotes that came with the car?   I hoping to use the remotes that come with the new alarm..  cuz my old ones don't work anymore =(
tabo
Member - Posts: 27
Posted: November 08, 2002 at 2:39 AM / IP Logged
btw: jon I only paid $24 for the remote starter kit =P  good deal?
