JL Amp and Sub install questions
acribb
Member - Posts: 20
Posted: March 21, 2005 at 11:29 PM / IP Logged
JL Amp and Sub install questions - Page 2 -- posted image.
acribb
Member - Posts: 20
Posted: March 22, 2005 at 4:29 PM / IP Logged
I’m trying to install an amp and sub to the factory system on my 2004 530i. It has the standard sound system, with a very small subwoofer amp. I’m planning on tapping in to those sub frequencies coming out of the stock subwoofer amp, using a line out converter (speaker level to RCA converter) to my JL 2501 amp which will drive a JL 12w3 sub. I need some opinions on what is what on this stock wiring harness coming out of the small subwoofer amp on the standard U.S. audio system. This is the small silver box on the left side of the trunk. I’m pretty sure I know which ones are the speaker wires, I just don’t know what the positive and negative wires for each one are, or how to test the polarity. I’m open to suggestions. Thanks.
Factory wire harness:
Going from left to right. SMALL BLACK WIRES-input signal from head unit (MASK computer). FIRST SUBWOOFER PAIR-BROWN / white stripe, RED / blue stripe. SECOND SUBWOOFER PAIR-BROWN / yellow stripe, RED / white stripe. AMP REMOTE TURN-ON-small white wire. POWER-thick red wire. GROUND-thick brown wire.
acribb
Member - Posts: 20
Posted: March 22, 2005 at 7:41 PM / IP Logged
I would be most appreciative if someone could help me out with this info...^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Thanks.
acribb
Member - Posts: 20
Posted: March 23, 2005 at 7:07 PM / IP Logged
Bump.
customsuburb
Gold - Posts: 1,813
Posted: March 23, 2005 at 9:24 PM / IP Logged
Just a guess
BROWN / white stripe - subwoofer 1 -
RED / blue stripe - subwoofer 1 +
BROWN / yellow stripe - subwoofer 2 -
RED / white stripe - subwoofer 2 +
The RED / blue stripe and RED / white stripe are probobly the positive outputs because the + power wire going to the amp is red and the - ground wire going to the amp is brown...it's worth a try.
customsuburb
Gold - Posts: 1,813
Posted: March 23, 2005 at 9:33 PM / IP Logged
Read here: http://www.bmwtips.com/tipsntricks/tips_pages/E39%20speaker%20color%20codes%20(non-DSP).htm (the note at the bottom confirms that the info i listed above is true) JL Amp and Sub install questions - Page 2 -- posted image.
acribb
Member - Posts: 20
Posted: March 23, 2005 at 10:11 PM / IP Logged
Nice.  Very nice.  Thanks, and now makes perfect sense.
**Now**  - just a few more little questions:
The JL 2501 amp has an input voltage selector of low and high.  Obviously, the manual says set it on low if you're using line-level inputs, and then the funny thing, high if you're using speaker level inputs but with soldered RCA plugs onto the ends.  The manual goes on to say that you can just use one input connection, left or right, but that a Y-adaptor would be recommended.
So which option would you go with?
1. Tap into both subwoofer leads (+ and - each speaker) off the factory sub amp and solder some RCA plugs onto them and hook em up to the amp, High voltage setting.
2. Tap into one subwoofer lead (one + and -), and solder an RCA plug to it then connect to amp with Y adapater, high voltage setting.
3. Use a LOC converter for both subwoofer leads to RCA on the amp, low voltage setting.
4. Use a LOC converter for one subwoofer lead to RCA on amp with Y-adaptor, low voltage setting.
I'm feeling #3 seems to be the best answer, but maybe 4 would be ok (and less work).  What would get the best signal to the amp?
Also, is me tapping into these speaker wires going to take any power away from the factory subs?  I wouldn't think so since there really isn't any resistance being added....
Thanks again.
customsuburb
Gold - Posts: 1,813
Posted: March 23, 2005 at 10:51 PM / IP Logged
Number 3 sounds right. Just buy an LOC and use the low voltage setting on the amp probobly.
acribb
Member - Posts: 20
Posted: March 24, 2005 at 8:28 PM / IP Logged
Once I tap into these leads, before I hook up to the LOC, can I test the wires with a multi-meter?  If it's a postive speaker lead, it will show voltage, if it's negative, it won't show voltage, right?  Sorry for my ignorance as i've never tested voltage on speakers before......
acribb
Member - Posts: 20
Posted: March 25, 2005 at 10:07 PM / IP Logged
Bump.
Page of 3
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
