4001 diode on dodge single pulse doors
kerckhof
Posted: March 27, 2005 at 4:42 PM / IP Logged
has anybody had to worry about the resistance of the 4001 diodge on a single wire pulse door lock system on a dodge ram pickup when using it between the alarm module and the resistors.
Darrel
auex
Platinum - Posts: 5,041
Posted: March 27, 2005 at 4:50 PM / IP Logged
Why would you use a diode for this???
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
kerckhof
Posted: March 27, 2005 at 4:54 PM / IP Logged
On the designtech 20092 system the two wires that control the unlock/lock pulse the diodes are used to block the power from these wires from going into the dodge wires, but allow the grounding of the dodge wires thro the module to ground.
Darrel
auex
Posted: March 27, 2005 at 4:58 PM / IP Logged
I still don't understand why you need diodes for this? You are supposed to use relays when integrating into 1 wire lock systems and the relays isolate the alarm from the car.
kerckhof
Posted: March 27, 2005 at 5:01 PM / IP Logged
can you give me a diagram has to how to do it to just double check mine is working, because my system isn't working correctly.
Darrel
thepencil
Gold - Posts: 1,526
Posted: March 28, 2005 at 6:42 PM / IP Logged
Diode is not necessary for your application.
This is the way to do a single wire door lock. Sometime you have to play around with the resistor to get it working correctly.
How to wire up single wire door lock & unlock system
Be careful whose advice you buy, but be patient with those who supply it.4001 diode on dodge single pulse doors -- posted image.
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
