Use Tweeters with Headunit’s Amp?
aez987
Member - Posts: 7
Posted: March 30, 2005 at 2:26 PM / IP Logged
Currently, I have a Kenwood headunit that has 50Wx4. I have a three amp system, so currently I'm not using the internal amp of the headuit.
Here's the issue: I want to add an additional set of tweeters - just tweeters. They are rated at like 50w RMS.
Can I connect them using the speaker wires from the headunit, even though I'm utilizing the headunit's RCA output already?
Will this work? Any drawbacks? Any one try this?
Thanks in advance for your feedback.
dwarren
Posted: March 30, 2005 at 3:05 PM / IP Logged
There is nothing wrong using the decks amplifier, however you will need to have some sort of x-over set up either from the deck or a passive one that comes with the tweeters, otherwise if you play them full range they won't last long
Why do feel the urge to add a second set of tweeters?
geepherder
Platinum - Posts: 3,668
Posted: March 30, 2005 at 8:34 PM / IP Logged
Yes, this will work, put some 4.7uf caps on them.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
