How do you thin resin for fleece?
BoominRolla
Copper - Posts: 198
Posted: April 05, 2005 at 4:58 PM / IP Logged
I thought acetone prevents the resin from drying are y'all just messing with me?? I thought you were supposed to put your paintbrushes in acetone to prevent them from hardening?...
oonikfraleyoo
Gold - Posts: 1,069
Posted: April 05, 2005 at 7:12 PM / IP Logged
If you only add a little acetone, it will thin the resin. It may take a little bit longer to dry but it will dry. No joke.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
bluetruck
Copper - Posts: 115
Posted: April 07, 2005 at 12:10 PM / IP Logged
acetone will keep the resin from curing but it also evaporates like my buzz when the cops show up. so it evaporates and the resin drys. ~Ryan
abovestock
Copper - Posts: 247
Posted: June 12, 2005 at 12:40 AM / IP Logged
Use MEK, it is already present in the resin. Also if you go to uscomposites.com they sell a chemical used just for thinning polyester resin. Also before any of you think that MEK is used to harden the resin, it is not, MEK is the carrier of the active ingrediant known as peroxide, Hence MEKP.
playr747
Copper - Posts: 65
Posted: June 14, 2005 at 8:18 AM / IP Logged
Proper thing to use to thin resin is Styrene at a 1/10 ratio
