2001 civic power cable routing
bebitte
Posted: April 05, 2005 at 12:37 PM / IP Logged
Hi I have a 2001 civic SI coupe or EX in USA and i was wondering where the best place to route my power cable through the firewall. I am using a 8 gauge wire. I wanted to make it go through the rubber seal on the passenger side floor where the cabling already goes through but i would have to make a hole in the seal and i don't want moisture coming in there. Anyone has a better place to make it go through or a good way to seal the hole? Thanks.
tcss
Silver - Posts: 1,623
Posted: April 05, 2005 at 6:27 PM / IP Logged
Should be a factory grommet near the steering shaft under the hood that you can pierce and get 8ga thru.
geepherder
Platinum - Posts: 3,668
Posted: April 05, 2005 at 9:40 PM / IP Logged
Just go through there and use some silicone sealant if you're worried about moisture.
bebitte
Posted: April 07, 2005 at 9:17 AM / IP Logged
This worked well thanks guys.
