Alarm making whirling snd w/ light flash
Illuminatrix1
Posted: April 08, 2005 at 12:25 AM / IP Logged
I have an audiovox 800 car alarm installed on a bronco ii the siren seems to be connected to the headlight flash.
I have connected the light flash lead white to the brown wire for the parking lights and the siren wire is connected for positive output to the siren.
When I diarm or arm there is a quick sharp chirps and then a whirling sound as the lights flash.
Thanks for the help
Cheers
auex
Platinum - Posts: 5,041
Posted: April 08, 2005 at 12:46 AM / IP Logged
Is the sound really muffled and not at full volume?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Corsicaboy
Member - Posts: 6
Posted: April 19, 2005 at 2:33 AM / IP Logged
Sounds like you have a bad ground. Check the groud wire connection for the main wiring harness.
Powermyster
Silver - Posts: 962
Posted: April 19, 2005 at 11:54 AM / IP Logged
came across this in sound systems where people have run RCA Leades with the power or else crossed the leads at the amp never heard of it in an alarm
harrisrc
Member - Posts: 6
Posted: April 20, 2005 at 4:06 AM / IP Logged
Like Auex and Corsicaboy say if it is a really low muffled whirling sound, it is a very high probablility that your alarm does not have a good ground.  Try replacing the ground to the main module and see if that corrects your problem.
