trunk release
t HALL
Posted: April 12, 2005 at 6:49 PM / IP Logged
I hooked up my trunk release to my 520s car alarm and it would't open the trunk when i press the trunk button on my remote then i took a test light and put one end to12v and the other end on the gray wire and it would not light up i hooked up a 30 amp relay to it i installed the trunk release  myself i have a 2005 pt cruser
Thanks TIM
mladams
Copper - Posts: 57
Posted: April 12, 2005 at 7:08 PM / IP Logged
definitely use a relay for the trunk release.  Without it you will burn out the module.  Make sure any wire connections are soldered, and if you can use a multimeter.  Sometimes the unit can't produce enough to light a bulb.  It's only about 200 mA. Deffinitely try chacking it with a multimeter or voltmeter.
Matt Adams
Electrical Engineer Major
York College of PA
Chevy Cavy Rally Sport
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
