Install Tecvox in Nissan Altima 2000
terrortwinn
Posted: April 25, 2005 at 11:01 AM / IP Logged
I want to install a remote starter into my nissan altima 2000.  I seen the diagram, but its not enough i don't think.  The wiring in Tecvox TC-4182 and there is alot of wires... prob like 25 wires or so.  Thank you
Scorpiotwinn
thepencil
Gold - Posts: 1,526
Posted: April 25, 2005 at 11:21 AM / IP Logged
I don't know what you are looking for, but sound like you need a wiring diagram for you vechile. That's my guess.
DIRECTWIRE™ WIRING INFORMATION - NISSAN / ALTIMA / 2000 / Remote Start
12volts WHITE/ red    +   ignition harness
Starter BLACK / YELLOW    +   ignition harness
Second Starter BLACK/ blue    +   ignition harness
Ignition BLACK/ red    +   ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ pink    +   ignition harness
Second Accessory WHITE/ blue    +   ignition harness
Keysense
Power Lock gray    -   smart entrance control
Notes: The smart entrance control unit is located to the right of the steering column. It is black or blue in color.
Power Unlock purple    -   smart entrance control
Lock Motor RED / blue      smart entrance control
Unlock Motor yellow      smart entrance control
Parking Lights+ RED / blue      steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white    -   drivers kick panel or SECU
Notes: To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin red or RED / blue    -   light in trunk
Hood Pin pink/black    -   smart entrance control
Trunk/Hatch Release ORANGE / black    -   smart entrance control
Power Sliding Door
Factory Alarm Arm lt GREEN/ red    -   smart entrance control
Factory Alarm Disarm GREEN/ YELLOW    -   smart entrance control
Disarm No Unlock
Tachometer WHITE/ black      6 pin plug at distributor
Wait to start
Brake Wire RED / green    +   brake pedal switch
Parking Brake
Horn Trigger brown or grn/yel    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.Install Tecvox in Nissan Altima 2000 -- posted image.
