Signal lights: one fast, one slow
NotoriousTCD
Posted: April 27, 2005 at 6:45 AM / IP Logged
got the oil changed, had some rear light bulbs replaced.  Before this both turn signals blinked at a rapid pace.  Now...the right is still rapid, but the left is at a normal/common speed.  96 Mitsubishi Eclipse GS-T 2.0 FWD.  Any thoughts???
mtamburro
Member - Posts: 6
Posted: April 30, 2005 at 7:31 PM / IP Logged
Check to make sure that the right side turn signals work. On several cars, the turn signals will blink rapidly when a bulb is out to remind you to fix the bulb.
auex
Platinum - Posts: 5,041
Posted: April 30, 2005 at 8:36 PM / IP Logged
You have a burnt bulb.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
led_creations
Posted: June 17, 2005 at 1:21 AM / IP Logged
If they were blinking very fast to begin with it would indicate there was a less than normal load on both sides especially if there are LED's on either the front or rear.When they started blinking normal the load on that side returned to normal. Check the grounds at all T/S lights. Corroded and/or loose ground connections  cause most intermittent lighting problems.
If at first you dont succeed, try reading the directions
bigburb
Posted: July 15, 2005 at 11:38 PM / IP Logged
if they replaced one side with a bulb that did not have the same wattage, for example a 3057 instead of 3157, it can cause them to blink at different paces.
also chekc and see if you still have a bulb out somewhere
nowlater123
Copper - Posts: 61
Posted: July 18, 2005 at 12:25 AM / IP Logged
Check to see if the blinker relay is working properly. It might have been knocked about when you had the car serviced.
Kenwood all the Way!
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
