amp install 2001 cavalier
e40water
Member - Posts: 47
Posted: April 30, 2005 at 10:56 PM / IP Logged
Hey guys, I have been working on upgrading my stereo in my 2001 cavalier, Ive installed aftermarket cd player / Just installed new 6x9's in the rear deck area. Now I got left is my door speakers and Amp install. The question I am needing help with is the wiring to the side post battery, Ive done alot of installs on other cars, New ones I am little caution, I am just needing some idea's of how to get wiring connected to the side post battery for a good connection.  * Note I have all the proper wiring for the amp JBL 360watt 4 channel. Any Idea's or tips would be greatful accepted.
e4
KarTuneMan
Platinum - Posts: 7,056
Posted: May 01, 2005 at 12:27 AM / IP Logged
You should have an accesory "post" that says battery....for a jump.....? Under a red plastic cover....
That where to grab 12 volts from the battery.........If not, go to where the Alternator cable goes into the under hood
fuse box....
rallysport
Copper - Posts: 172
Posted: May 01, 2005 at 12:40 AM / IP Logged
you could also get one of them gm side post terminals at any car audio shop, i used to have a cavalier and the aftermarket terminal made it easy.
e40water
Member - Posts: 47
Posted: May 01, 2005 at 12:41 PM / IP Logged
Awsome guys thanks for youre tips and info.
e4
racer427
Silver - Posts: 381
Posted: May 01, 2005 at 7:58 PM / IP Logged
This is what you will need to connect power wire to a Side post battery.
http://www.cardomain.com/item/LITSMB1
I use these to upgrade the factory grounds from the battery as well.
Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
