Sub direction
wrathchild281
Copper - Posts: 241
Posted: May 01, 2005 at 9:45 PM / IP Logged
hey you guys i have 4 12's and there going in a ported box. There gonna be in the back of my dakota extended cab. I am taking out the back seat. I am not sure which way to direct them, either all 4 downfiring or all 4 facing towards the front of the car. I heard that if i point them all down it would probably be louder. Also im not sure if to port it or not, i have the airspace im just not sure if it will make a big difference. what do you guys think and also what does it mean to invert your subs, i read it on some other posts. thanks
95Pony
Member - Posts: 34
Posted: May 01, 2005 at 9:59 PM / IP Logged
Check out this article, its great tells you everything you need to know.
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=11;t=077267
Francious70
Silver - Posts: 629
Posted: May 02, 2005 at 12:35 AM / IP Logged
I'd say the front of the cabin. It's obvious you want to be loud, and that the way I always see big SPL guys (I mean high scoring) mount their subs.
Paul
Ravendarat
Platinum - Posts: 2,806
Posted: May 02, 2005 at 1:21 AM / IP Logged
I had 4 subs in my s-10 extended cab and fired all 4 of them strait ahead in a ported enclosure and won my local circuts. I ported my box quite low as well (27 hz) so it wasnt exactly a great spl box but it was my daily driver so I needed to retain a little sound quality ( BTW I took second in a sq contest as well). If I had tuned my box higher I could have hit higher numbers. I am a big fan of downfiring as well but there are a lot of subs out there that arent suitable for down firing aplications. And as for porting making a big difference, as a rule of thumb it does but some subs do preform better in a sealed enclosure so some model numbers along with the accompaning amp models that you are running the subs with would be a big help.
wrathchild281
Copper - Posts: 241
Posted: May 02, 2005 at 5:47 PM / IP Logged
ok well i bought 4 memphis power reference subs. What do you guys think i should do? port it or not.
wrathchild281
Copper - Posts: 241
Posted: May 02, 2005 at 5:49 PM / IP Logged
also i heard there more spl subs than sq subs and memphis recemmends that its ported at 40hz. Is that to high? im looking for some deep low bass.
racer427
Silver - Posts: 381
Posted: May 02, 2005 at 6:13 PM / IP Logged
Use this calculator to figure out wheather your subs are suitable for dowm firing.
http://www.accelerator-pedal.com/sag.htm
Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
wrathchild281
Copper - Posts: 241
Posted: May 02, 2005 at 6:43 PM / IP Logged
it says on my specs that the vas is 1.86 and the fs Hz is 33hz and the xmech is .352 does this sound correct it says its 65percent saggy and shouldnt be down fired.
racer427
Silver - Posts: 381
Posted: May 02, 2005 at 6:46 PM / IP Logged
Enter the vas in liters not ft3.
Chris
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
stevdart
Platinum - Posts: 5,816
Posted: May 02, 2005 at 7:55 PM / IP Logged
...and xmax is in millimeters, which in your case would be 9.  If your numbers for that calculator are 53 liters VAS, 33 Hz Fs, 9 mm Xmax, and it's a 12" sub, the percentage is 3%, which is okay for downfiring.  Copy and keep this unit converter.
