Window rollup stock alarm Neon SRT-4
b4tn
Member - Posts: 42
Posted: May 02, 2005 at 1:59 AM / IP Logged
Just wondering, I have a Neon SRT-4 with a factory alarm.  I also have a universal window rollup module.  I was wondering if it is possible to use the lock pulse from the factory lock to activate the rollup module?
Captanham
Silver - Posts: 365
Posted: May 02, 2005 at 2:22 AM / IP Logged
yea, you might need to get a pulse timer tho, depending on what kind of a window modual you have, i'm only familiar with dei and fusion, but most need a steady ground to roll them up, not a pulse (except the dei 529) but you can get a dei pulse timer for cheep, it will convert a ground pulse (from your unlock wire) to a 30 or so second ground output (that will be more than enough time for the windows to go up,, then you should have no problems, and these pulse timers are cheep no more then like 20 bucks i think
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Captanham
Silver - Posts: 365
Posted: May 02, 2005 at 2:27 AM / IP Logged
ohh and i mentioned the 529 but i didn't explain, the 529 has a pulse input for the window up, this input when tied in with the activation output will kind of  "latch" it'self on, that way it will continue rollingi down untill it see's that the window has stoped moving
now that i think of it, a dei 530 also has an active output, it's an output that goes to ground while it's rolling the windows up or down,, this is usually used to turn off alarm sensors IF needed,,, if you dioed this, and the regular activation input, and combine them, you might beable to make it latch it'self, without a timer, give it a try and see if it works,,, the only problem is,, this would have to be tested IN the car, because you can't test the 530 without a motor to use,, if you don't understand what i mean by connecting these wires i can draw you a simple diagram
there is also a way to do this with 4 relays, but i don't think you want to do that, and it would only work with the 530t
haha, sorry it's late at night and i get all sorts of crazy ideas when i'm on here
Bad Boys Customs
b4tn
Member - Posts: 42
Posted: May 02, 2005 at 10:11 AM / IP Logged
Not the same one but this is very similar its just a generic rollup module
http:///.com/dll?ViewItem&category=48611&item=5768953162&rd=1&ssPageName=WDVW
It was hooked up to one of my viper 790 aux outputs to roll the windows up when the car is locked but I honestly dont remember how I hooked it up to the viper lol I think I had a diode in there if I remember right..
Captanham
Silver - Posts: 365
Posted: May 02, 2005 at 10:49 AM / IP Logged
that's the same thing as the fusion one, i dont' have time right now to go grab a manual for one, but i will look later tonight and tell ya what you need
Bad Boys Customs
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
